Solution Solved: (I read this off another guy tho had this problem on your site {nice site btw}) If you have Alchohol 120% of any other progam this imulates a fake cd rom drive mobile media will not start up
I reinstalled but still I get the illegal operation:
EventType : clr_2_0_errorreporting_v1 P1 : mobilemediacenter.exe
P2 : 0.5.50404.1 P3 : 1087966828
P4 : system.management_ version=2.0.3600.0_ culture=neutral_ publickeytoken=b03f5f7f11d50a3a
P5 : system.management P6 : 2.0.40301.9
P7 : {3f9afea8-81e8-4600-b1b0-af5006bd7df4} P8 : 0x60000db P9 : 0x37
P10 : system.management.managementexception
This update should fix the message you were having Rith, plus it disables the DVD auto detection for now. It is very unstable. I apologize for this and I am working on working hard on the DVD code.
http://www.hybrid-mobile.com/mp3car/...ediaCenter.zip
user: mp3car
pass: user123
Ben S. Stahlhood II
Hybrid Mobile
MMC/Transcend Developer
http://www.cocoamachine.com/
http://weblogs.asp.net/bstahlhood/
Just finished the CD ripping code. Can rip CD's to MP3 or OggI am working hard to have it in the next release. Will post more info when I have it...
Thanks again everyone for the feedback and support.
Ben S. Stahlhood II
Hybrid Mobile
This new exe works fine for allowing us to still have an emulated CD/DVD-ROM but it will not find the right drive to scan for DVD-Media.Originally Posted by HybridEngineer
Previous release..
Disabled emulation drive setup by Alcohol 120%. MMC will run and DVD function will play DVD video from the DVD-ROM drive.
New exe..
Enabled emulation drive on system as secondary cd/dvd-rom drive letter (Physical DVD-ROM is at F:, and emulated cd/DVD-ROM drive letter is at G, MMC will not play DVD video from the Physical DVD-ROM drive. It goes to a black screen and nothing happens..
Possible solution?
Would it be possible to add a setting in the config file to label what drive letter the DVD-ROM drive is located at for proper playback?
VWMAN
"Live Long And Prosper"
car: VW Cabriolet '90
puter: M10000(toasted), Lilliput, CarNetix
status: In Progress
So, I'm running an epiah M10000 gig processor with 512 megs or ram, external Soundblaster Audigy 2NX, XMpcr, and a usb external hard drive, xp professional.
I tested the app last night with the music I had available, first I'd like to say this is the nicest looking app I've seen, I like the layout and love the interface. However I have issues, first the database issue with a screen shot below of the error message.
Second, it bogs the system down, heavily, when I start to listen to an mp3 it'll play for a few seconds then I get a nice sounding crackle the mp3 slows for a few seconds then continues, and does this repeatedly. It should be noted that all my mp3's are encoded as high quality variable bit rate mp3's. This issue might be due to the external sound card as I'm less then thrilled with it's perfomance, however this behavior is not present in any other media application.
Visuals are very nice... everything rocks except for the two issues above, here is a screenshot of the error I'm receiving when trying to build my database
don't know if it helps but here is the content of the error...
LOL, Check this out :http://www.inkoopactie.net/ia/8h66f2kx/1?g=bhp0mk3v
looks like we got a reseller
Only $5 for free software![]()
hi when i play any mp3 track i get a message box prompting me to quit or continue the app and the details button shows me the following infomation
what have i done wrong?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
Parameter name: handle
at HybridMobile.Media.Audio.AudioStream..ctor(Int32 handle)
at HybridMobile.Media.Audio.AudioEngine.LoadStream(St ring filename)
at MobileMediaCenter.MmcForm.hybridList_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.3600.0
Win32 Version: 2.0.40301.9 (pd4.040301-0900)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.40301/mscorlib.dll
MobileMediaCenter
Assembly Version: 0.5.50404.1
Win32 Version: 0.5.50404.1
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%202/MobileMediaCenter.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.3600.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.3600.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.3600.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.3600.0__b77a5c561934e089/System.Xml.dll
HybridMobile.Media
Assembly Version: 1.0.1635.13
Win32 Version: 1.0.1635.13
CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center%20Alpha%20Release%202/HybridMobile.Media.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.3600.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
