Thread: Archive
  1. #1791
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    2 days left. I hope you guys are on schedule.
    We are, will have and forever will be...
    But not tommorrow!
  2. #1792
    Mar 2005
    Quote Originally Posted by AlienEclipse
    I have still got the same problem that appeared with rev6.
    After the splash screen dissapears i get the "Just in Time Debugger" reporting that Mobile Media Center has caused an exception error. The process is left running using ~53MB or RAM.
    After rev6 didn't work i had hardware issues that got resolved. I ran a repair install of XP reinstalled SP2 reinstalled .net framework 2.0. Everything is installed and working perfectly, except for mobile media center.
    Yes i have removed all prior versions. I have tested it with and without paths entered in the config file.
    Hybrid Enigineers, DO YOU HAVE ANY IDEA WHAT COULD BE CAUSING IT?
    im having a similar issue. I will post a screen shot tommomrow. But one question i have is how many mp3's does he have in the directory?
    my base directory is 22.1 gigs of mp3's maybe to many files is the issue?
    also do i need to uninstall the dot net framework 1.1 for the 2.0 to be installed?
    Heres what I have:
    windows 2000 sp4
    dot net 1.1
    dot net 2.2
    winamp
    microsoft map point
    my d: drive is a 40 gig for mp3's (22.1 used)
    wmp11 wireless card
    P4 1.7
    256mb of Rambus ram
    3 hard drives
    a dvd burner
    ATI Video card
    any other information needed? (besides the screenshot i will post in the morning)
  3. #1793
    Jul 2003
    Don't mean to sound pushy, but here in NZ the fourth has come and gone.
    Where's BETA 1?
    But not tommorrow!
  4. #1794
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    What are you talking about - its about lunch time?!?
  5. #1795
    Mar 2004
    California
    only about 17 and a half hours left until the 4th has come and gone! (PST)
    tick
    tick
    tick
    tick...
    Kevin
    Audi A4 Carputer, 80% setup.
  6. #1796
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    lol..... I guess we should have said March 4th EST: here is the updated feature list to get you going: i will post some screen shots as well
    here is a list of features that are now supported on this version:
    1. 95% skinnability (video preview window size and medium view size yet to be implemented)
    2. update database on the fly by simply hitting a button (hybrid logo on home screen)
    3. USB thumb drive/ CDR media import support.(plug and play, media must be in root of drive for now)
    4. CD Ripping in .ogg format (just insert cd, and you will be prompted)
    5. Album art (folder.jpg file)
    6. keyboard shortcuts for all functions in MMC (see below)
    7. 10 Band EQ with an additional Band for Subwoofer boost (30hz)
    8. XM Radio
    9. DVD Video Playback
    10. All audio formats supported natively(.mp1, .mp2, .mp3, .mp4, .aac, .flac, .ovr, .wv, .ogg, .ape, .m4a)
    11. All video formats supported with installed codecs
    12. photo viewer (slideshow still needs work)
    13. Webcam support
    14. Relay control (w/ CECU only)
    15. Playlist generating, (press and hold to add to playlist, same to remove)
    16. Visualizations, can be changed by clicking the hybrid logo on the top of the visual window (.svp only for now)
    17. seperate mini visuals can be changed by clicking on the mini vis
    18. Embeded Apps (just specify the .exe path in the skin file)
    19. GPS (very very limited right now... that was the last major component to implement)
    Shortcuts
    Music window: ctrl + M
    video window: ctrl + V
    DVD window: ctrl + I
    GPS window: ctrl + G
    Camera window: ctrl + C
    Xm Radio window: ctrl + X
    Photo window: ctrl + O
    EQ window: ctrl + Q
    Home window: ctrl + H
    List: ctrl + T
    Shuffle: ctrl + F
    Reapeat: ctrl + R
    Visual: ctrl + Z
    Volume up: ctrl + U
    Volume Down: ctrl + D
    Next track: ctrl + N
    Previous track: ctrl + L
    Play/Pause: ctrl + P
    Search: ctrl + S
    Update Database: ctrl + B
    Scroll list Up: ctrl + Up
    Scroll list down: ctrl + down
    Jog forward (song): ctrl + right
    Jog reverse (song): ctrl + left
    EQ controls:
    Sub band up: Alt + `
    Sub band down: ctrl + `
    60 hz band up: Alt + 0
    60 hz band down: ctrl + 0
    170 hz band up: Alt + 1
    170 hz band down: ctrl + 1
    310 hz band up: Alt + 2
    310 hz band down: ctrl + 2
    600 hz band up: Alt + 3
    600 hz band down: ctrl + 3
    1k band up: Alt + 4
    1k band down: ctrl + 4
    3k band up: Alt + 5
    3k band down: ctrl + 5
    6k band up: Alt + 6
    6k band down: ctrl + 6
    12k band up: Alt + 7
    12k band down: ctrl + 7
    14k band up: Alt + 8
    14k band down: ctrl + 8
    16k band up: Alt + 9
    16k band down: ctrl + 9
  7. #1797
    Orlando, Florida
    are you guys selecting a whole drive for your media? it seems to me early on i was having a similar issue when i selected a drive letter as my media, as soon as i pointed it to a folder it was ok. most likely beta 1 should fix any problems that are being had
    BTW, you do not need to uninstall .NET 1.1
  8. #1798
    Low Bitrate Gene's Avatar
    Jun 2004
    Minnesota
    Sweet. Can't wait to try it.
  9. #1799
    Jul 2003
    Quote Originally Posted by mpattonm
    Its now lunch time on the 5th of March (saturday).
    But not tommorrow!
  10. #1800
    Maximum Bitrate Bitoholic's Avatar
    Port Saint Lucie, FL
    *FRONT END* Mobile Media Center Beta 1 Download Now!!
    Here it is:
    Damn your impatient!! lol
    YOU MUST UNINSTALL PREVIOUS VERSIONS OF .NET 2.0 first (.NET 1.1 can remain on your machine this only applys to 2.0)
    THEN YOU MUST INSTALL .NET 2.0 BETA 2 get it here: http://www.hybrid-mobile.com/mp3car/dotnetfx.exe same user/pass as below
    You must also uninstall any previous versions of MMC prior to install
    Now go to:
    USERNAME: mp3car
    PASSWORD: finalnext
    8. XM Radio
    13. Webcam support
    Shortcuts
    EQ window: ctrl + Q
    List: ctrl + T
    Shuffle: ctrl + F
    Reapeat: ctrl + R
    Visual: ctrl + Z
    Volume up: ctrl + U
    Search: ctrl + S
    EQ controls:
    1k band up: Alt + 4
    3k band up: Alt + 5
    6k band up: Alt + 6
    Ben S. Stahlhood II
    Hybrid Mobile
    MMC/Transcend Developer
    http://www.cocoamachine.com/
    http://weblogs.asp.net/bstahlhood/
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 06:34 AM
  2. Frodo's Files Archive!
    By kujosan in forum FrodoPlayer
    Last Post: 09-24-2006, 10:24 PM
  3. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 05:01 AM
  4. FOR THE LOVE OF ALL THATS HOLY AND DECENT, NO MORE ARCHIVE POSTS!!!
    By sleddog4 in forum General Hardware Discussion
    Last Post: 10-30-2000, 10:25 PM
