Thread: Archive
  1. #1821
    Maximum Bitrate Bitoholic's Avatar
    Port Saint Lucie, FL
    Quote Originally Posted by The Grinch
    Ok...installed and testing on my home PC. So far it's looking pretty good.
    I love the built in EQ. My car will be so much happier now. Is there a way for me to tweek the response speed of the EQ? I know that it could cause playback issues, but it would still be nice to have control over.
    no you cant adjust that, its the way the dsp filters are used.
    Ben S. Stahlhood II
    Hybrid Mobile
    MMC/Transcend Developer
    http://www.hybrid-mobile.com/
    http://www.cocoamachine.com/
    http://weblogs.asp.net/bstahlhood/
  2. #1822
    New York
    so just curious why does everyone want the front ends to resume when you load the program? I use hibernate and it starts back up exactly where it left off... what is the reason for shutting down the cpu instead of hibernating?
    For me, there is no gain by going to hibernation. With startup times under 30seconds and remote start, the system is running by the time i enter the car. Plus, no startup/shutdown controller. I just kill the power at will with pulling out the key.
    Anyways, it seems that video mode is a little spotty. It works, but at random it hangs. One such example I have is switching between videos. Sometimes, I can switch from Video 1 to Video 2 without a hitch (while video is still playing). Other times, when I click on the second video, there is some hard drive activity, and then MMC just stalls out and hangs and does nothing. This happened on both WMV and MPEG files in my case.
  3. #1823
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Hibernation is the only choice for me.
    I've been doing a little testing on my home PC and I noticed that while playing videos the Windows screen saver still kicks in. Usually when you are running a program like Windows Media Player, the screen saver is bypassed. Could this be implemented? The screen saver is fine for playing music, but annoying when video is playing. I guess depending how you look at it, this is more of a feature request than a bug.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  4. #1824
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Quote Originally Posted by HybridMike
    i just checked something and if the default path to mspaint that we put in the skin file is not right, it will behave that way.....just change the path to any other program you want to embed...see it that helps
    No, that didn't help. Seem its the first run of the application, the first thing it asks for is to select the external audio input device. Now you might remember that with alpha rev 8 i posted the same fault. I would get the just-in-time debugger coming up after the splash screen disappears. Know at that point the selection box should appear. After it happened the first time, i rebuilt my system and the fault was still there. This was never resolved, and i believe its the same issue again. I have a Creative SoundBlaster Audigy 2 ZS in my system. Has anyone got this card and using MMC? I have driver version: 5.12.2.444
    Do any of the hybrid developers have the same card they could test with.
    I installed .net 2.0 beta 2 and MMC on my CarPC last night. The first run ran fine. However, after the database was built the application closed with no error. Now everytime i run it, it closes after the splash screen without a trace.
    My CarPC is based on a VIA M10000, and for now i'm using the onboard sound.
    We are, will have and forever will be...
    But not tommorrow!
  5. #1825
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    did your car pc have mmc installed previously? because the media.xml file will stay even after uninstalling.... if this is the case delete the media.xml file and reset your paths in the config file and run it again in either case try this again.... I have a audigy 2 external sound card, however mine worked fine on the last version, i will try it on this one too.... ben is coming back monday night and will update beta 1 to clear up as many issues as we can
  6. #1826
    Mar 2004
    all you need to do is insert a usb drive or cd with media on it. mmc will do the rest and update the database
    Not really a solution. That doesn't answer the need to upload music from my PC's HDD or being forced to manage your music from inside your car.
    This is basically what I was thinking...
    "In addition to this, there will be a program called "AstraMac Companion". You will be able to install it on the carputer itself or any other machine that has network access to AstraMac. It'll let you manage music libraries, do advanced configuration, install skins, perform program updates and so on. " New Mac Front-End (in progress): AstraMac
  7. #1827
    Jul 2003
    No, the install on my carpc is fresh (no previous traces of MMC or .net)
    The first paragraph of my last post was to do with my main (desktop) PC. And i had removed everything to do with MMC before installing the new version.
    But not tommorrow!
  8. #1828
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Could it have anything to do with an New Zealand-version of windows? Seems the only connection between the 2 pc's...
  9. #1829
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    so i downloaded it uninstalled the previous version and .net, installed the new .net and the new version and whenever i run it my cpu runs at about 100% for 20 odd seconds and then i get a "mobilemediacenter.exe has encountered a problem and needs to close"
    AppName: mobilemediacenter.exe AppVer: 0.5.1000.3 AppStamp:4228ed2d
    ModName: ntdll.dll ModVer: 5.1.2600.2180 ModStamp:411096b4
    fDebug: 0 Offset: 0002ae22
    i dunno if any of that helps or u need the rest, any ideas?
    Signature: [==||========] 20% complete
  10. #1830
    Orlando, Florida
    our version 2 "Transcend" platform will have that buit in, just not for version one
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 06:34 AM
  2. Frodo's Files Archive!
    By kujosan in forum FrodoPlayer
    Last Post: 09-24-2006, 10:24 PM
  3. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 05:01 AM
  4. FOR THE LOVE OF ALL THATS HOLY AND DECENT, NO MORE ARCHIVE POSTS!!!
    By sleddog4 in forum General Hardware Discussion
    Last Post: 10-30-2000, 10:25 PM
