Thread: Archive
  1. #1841
    Quote Originally Posted by AlienEclipse
    As for my carPC, MMC still disappears after the splash screen.
    Same issue here. My home machine it loads great, I've also run into the pictures bug. The carpc though it shoes the splash screen and then nothing. Doesn't even stay running. I do have a nlite'd version of XP, however I've spent hours removing only components I didn't need. All the other front ends work.
  2. #1842
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    we are aware of the photo bug, its a simple fix...just that we keep forgeting about it...ugh!
    I am lovin this software, its beautiful.....def needs support for ID3 tags
    what do you mean? we support ID3 version 1 and 2 tags (unless you are refering to ripping... in that case we are working on it, just wanted to get the feature in first and test)
    as far as alieneclipse's problem...we will have to wait for ben to get back to figure it out
    that problem is indicitive of a problem with something in the default.xml
    try the file below and copy over your default.xml file with this updated one and see if it fixes it:
    right click below and select save target as... then save it in the membrane folder of mmc "c:\program files\Hybrid Mobile Technologies\Mobile Media Center\Membranes" copy over the old one
    try this
  3. #1843
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    .NET 2.0 link seems down... or it could be me.
  4. #1844
    Orlando, Florida
    i just tried it and it worked.... it is a user/pass login before downloading, check your browser settings... or go to www.hybrid-mobile.com/mp3car and get there that route
  5. #1845
    Mar 2004
    Ghent - Belgium
    Thanks, got it at MS
  6. #1846
    Orlando, Florida
    make certain it is in fact beta 2 of .net... last i checked it was not available at Microsofts website
  7. #1847
    The land of polar bears and nekkid blonds
    Tried it this weekend, but I'm having the same problem as a lot of us have had since day one.
    The media database is built, but then on the old versions it crashed, now it just exits silently.
    /M
  8. #1848
    Low Bitrate Gene's Avatar
    Jun 2004
    Minnesota
    Can't scroll anymore. Also, when I go to my photo albums I get this message:
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileNotFoundException: C:\Documents and Settings\bldg tech\Desktop\Desktop Icons\Pix\
       at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
       at System.Drawing.Image.FromFile(String filename)
       at MobileMediaCenter.MmcForm.photoListBox_Click(Object sender, EventArgs e)
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.3600.0
        Win32 Version: 2.0.41115.19 (lab23df.041115-1900)
        CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.41115/mscorlib.dll
    MobileMediaCenter
        Assembly Version: 0.5.1000.3
        Win32 Version: 0.5.1000.3
        CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/MobileMediaCenter.exe
        CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.3600.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.3600.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.3600.0__b03f5f7f11d50a3a/System.Drawing.dll
    Intellified
        Assembly Version: 1.0.1889.33005
        Win32 Version: 1.0.1889.33005
        CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/Intellified.dll
    System.Xml
        CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.3600.0__b77a5c561934e089/System.Xml.dll
    Destinator
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/Destinator.dll
    System.Data
        CodeBase: file:///C:/WINNT/assembly/GAC_32/System.Data/2.0.3600.0__b77a5c561934e089/System.Data.dll
    HybridMobile.Media
        Assembly Version: 1.0.1889.33006
        Win32 Version: 1.0.1889.33006
        CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.Media.dll
    HybridMobile.Xm
        CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.Xm.dll
    HybridMobile.DirectX.DirectShow
        CodeBase: file:///C:/Program%20Files/Hybrid%20Mobile%20Technologies/Mobile%20Media%20Center/HybridMobile.DirectX.DirectShow.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
  9. #1849
    Jun 2004
    Minnesota
    Quote Originally Posted by Peoples
    also, if repeat and shuffle are on at the same time, shuffle does not shuffle
    Why would you want "repeat" and "shuffle" on at the same time?
  10. #1850
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Now that MMC has a full EQ, I came up with a nice idea. A Bass Boost button. There are some tracks that are just plain lacking on bottom end. A bass boost button would be a nice touch.
    Hang on... keep reading.
    I would make that option configurable by the user so he/she can define if the bass boost should be active globally or only active on a per/song basis. In other words, when the song is over, bass boost automically disables. A three phase button maybe?
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 05:34 AM
  2. Frodo's Files Archive!
    By kujosan in forum FrodoPlayer
    Last Post: 09-24-2006, 09:24 PM
  3. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 04:01 AM
  4. FOR THE LOVE OF ALL THATS HOLY AND DECENT, NO MORE ARCHIVE POSTS!!!
    By sleddog4 in forum General Hardware Discussion
    Last Post: 10-30-2000, 09:25 PM
