Thread: Archive
  1. #1991
    Maximum Bitrate Bitoholic's Avatar
    Port Saint Lucie, FL
    Quote Originally Posted by RoyN
    It doesnt need specific testing as he is using the Destinator platform... the maps/route calculation/etc is the same *** all other systems that use this (Map Monkey, Freedrive, Centrafuse)
    Bitoholic, are you going to abandon the integrated destinator? I'd favor integrated phone, but integrated destinator is nicer than embedded...
    I am still going to do integrated Destinator, but use MapMonkey for right now until its done so that you guys have something to use.
    Ben S. Stahlhood II
    Hybrid Mobile
    MMC/Transcend Developer
    http://www.hybrid-mobile.com/
    http://www.cocoamachine.com/
    http://weblogs.asp.net/bstahlhood/
  2. #1992
    Quote Originally Posted by camsgs3
    hybrid guys, im really losing my patience on gettin MMC working....
    I installed the first version of .net 2, then uninstalled, reinstalled the new one and still have nooo luck runnning it on my machine
    here is my error log:
    Application Session Started 3/11/2005 9:32 PM
    Information logged at 9:32:46 PM
    Initializing Components...
    Switching DVD Region to Region Free...
    Information logged at 9:32:47 PM
    Initializing Sound Engine... Device Found - NVIDIA(R) nForce(TM) Audio
    Loading Winamp Input Plugins...
    Getting media paths and checking media database...
    I get nothing at all, at first i thought maybe it was because it had a problem reading my 10,000+ MP3's, so i just pointed it to about 3 ablums and still the same thing
    my PC specs are:
    AMD 2700+
    1Gig Ram
    XP SP2 PRO
    ATI 9600 AIW
    MMC 1 r.4
    Sorry! I am constantly making bug fixes and I hope I can nail the one that is causing you problems, I really want you to be able to use it and give feedback.
    Ben S. Stahlhood II
    Hybrid Mobile
  3. #1993
    Quote Originally Posted by Nic
    the lastest revisions have fixed the problem with crashing i was experiencing so i thought i'd give you some feedback, the app seams clean and fast which is good but its fairly useless to me because of the way my music is organised.
    my music is in 5 genre folders within each folder is a whole lot of loose files and more folders containing albums, almost all the albums are compilations which are mixed together between songs, ripped in ogg to be gappless
    for a start the player dosent play back gaplessly, the only players i have used so far that play back truly gapless are foobar and winamp (with the correct plugin and only in gapless formats such as ogg). Additionally the files aren't in the correct order, which i find pretty important for a mixed cd.
    What i do currently is have a playlists folder (full of m3u's of albums and play all for a given genre) and set the "music library" of my frontend (mediacar/roadrunner) to this folder, therefore i am always loading playlists from the library rather than the files, so i always get the correct order. MMC doesnt seem to like m3u files.
    This post is basically a feature request as well as asking for a reccomendation, is there any better way of doing this rather than having to update and create playlist files all the time? perhaps the frontend could read the track number in the ogg file?
    I will be adding support for playlist files (m3u, etc), OGG comments (track number, so I can order by track), and I will be make the list display in track order for Albums on all formats I support tag info on...
    Ben S. Stahlhood II
    Hybrid Mobile
  4. #1994
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    ignore this post...oops
  5. #1995
    Bitoholic: did you think about my idea for speech?
    Instead of having <MAGICWORD> <COMMAND> <MAGICWORD><COMMAND> evferytime having to repeat the word MMC (), would it be opssible to do a word that makes it start listening to the shorter commands?
    Like:
    - MMC
    *reply: "listening"
    - PLAY BARRY WHITE (just an example)
    *reply beep (optional)
    - JOG 30
    - VOLUME 50
    - OKAY
    *reply double beep (optional)
    Yes and I like it! I will be trying this out once I get the other main features in such as Browser and PhoneCo
    Ben S. Stahlhood II
    Hybrid Mobile
  6. #1996
    Jan 2004
    NYC
    just tried r.5 still the same problem
  7. #1997
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by Bitoholic
    thanks, sounds good but the playback still wont be gapless will it?
    Signature: [==||========] 20% complete
  8. #1998
    I get this error every time I exit (click the house) from the EQ screen.
    System.NullReferenceException: Object reference not set to an instance of an object.
    at HybridMobile.Media.Video.CameraPanel.Stop()
    at MobileMediaCenter.MmcForm.ProcessMmcMessages(Strin g message)
    at MobileMediaCenter.MmcForm.buttonPanel_MouseDown(Ob ject sender, MouseEventArgs e)
    at System.Windows.Forms.Control.OnMouseDown(MouseEven tArgs e)
    at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Also this version seemed to overwrite my previous monkey map install. Is there a way to have it check for the latest and not overwrite? (I had the latest) Cant wait for phone control!!
  9. #1999
    How is your folder set up? Is your music on a networked drive? I am just wondering how different yours is, maybe its confusing MMC?
    If you could give me some more detail. The log says it crashing on checking media paths and database. So I want to see what it is about the Paths that might be different...
    Ben S. Stahlhood II
    Hybrid Mobile
  10. #2000
    I am adding gapless and crossfade features tonight
    Ben S. Stahlhood II
    Hybrid Mobile
  1. Alpine
    By more mods in forum RR Skins
    Last Post: 04-10-2008, 05:34 AM
  2. Frodo's Files Archive!
    By kujosan in forum FrodoPlayer
    Last Post: 09-24-2006, 09:24 PM
  3. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 04:01 AM
  4. FOR THE LOVE OF ALL THATS HOLY AND DECENT, NO MORE ARCHIVE POSTS!!!
    By sleddog4 in forum General Hardware Discussion
    Last Post: 10-30-2000, 09:25 PM
