Results 1 to 2 of 2
Thread: Community Innovation: Poor Man's Ground Loop Isolator- 10/23/08
    Low Bitrate vtecfelon23's Avatar
    Dec 2007
    Baltimore
    A very common topic on the Mp3Car Forums is getting rid of strange audio noise (typically synchronous with the rev of your engine); an odd humming or whining sound. This is generally caused from using multiple ground points in your setup. Because these points are connected to a common ground but from different locations, unsteady or irregular voltage may occur. We can separate the grounds from each other by using a Ground Loop Isolator.
    Here is an old one from the archives-
    ground loopForum member Gip shows us how the poor man constructs his own Ground Loop Isolator. He uses two transformers removed from a couple of old 56k modems, an RCA adapter and some breadboard. Put it all together and viola... no more audio noise. Originally posted as a means to "remove power supply noise from audio". See more pictures and a full explanation on the thread.
    In addition to using a GLI, it is also preferred to use high quality shielded cables, and to keep any power lines away from your signal lines - Make Oersted proud!
    For further information on this topic consult the Car Audio section of our forums or see the Induced noise FAQ
    If you have alternate solution to problematic audio noise you feel should be recognized make a post in the Mp3Car Blog Talk section.
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by vtecfelon23 View Post
    Great blog post. Too bad we recycled all our old 56k modems.
  1. Ground Loop Isolator Question
    By rich3327 in forum General MP3Car Discussion
    Last Post: 02-16-2008, 11:49 PM
  2. PAC SNI-1 Ground Loop Isolator & RCA Noise Filter
    By bambam in forum The Review Palace
    Last Post: 02-06-2008, 12:35 PM
  3. Ground Loop - can't I just go direct to terminal?
    By Red_Beard in forum Power Supplies
    Last Post: 01-13-2008, 02:52 PM
  4. Replies: 4
    Last Post: 09-09-2007, 12:28 AM
  5. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 02:38 AM
