Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: CES 2009 - Lilliput & Their New Products
  1. #11
    Jan 2009
    correct me if i'm wrong, but i don't know if there'd be a massive difference in picture quality using a DVI connection over a VGA connection on a 7 or 8 inch monitor. of course, with CCFL to LED there was a significant difference, especially on smaller screens. what kind of picture quality improvements could we expect from a DVI interface?
  2. #12
    May 2006
    Simi Valley, CA
    I think the biggest advantage of DVI would be compatibility. I know on my motherboard I could add another monitor without any other upgrades as long as it's digital (DVI).
    This is a quote from an old nvidia forum topic:
    vythiel
    Nov 9 2007, 11:00 PM
    DVI - information goes directly from your video card to your monitor. The color of each pixel on your monitor is calculated by your video card and then sent as digital information to your monitor so that no conversion is necessary. An LCD monitor simply reads this information and displays it directly
    VGA - Information is converted from digital to [red,green,blue] format. Some accuracy and time is lost in this converstion. How much is lost depends on the monitor's conversion hardware.
    Image Quality:
    On a CRT monitor, there is no real image quality difference between DVI and VGA. This is because a CRT is natively based on the [red,green,blue] format for displaying each pixel.
    On an LCD, you will notice a difference between the 2 formats if you look hard enough. Different LCDs will handle the conversion differently. You may start to see dithering, banding, "dancing pixels" and blander/incorrect colors when using vga on an LCD. The larger the LCD/resolution the more you will notice these differences.
    DVI also has a faster data transfer rate, which means that the higher the resolution, the worse the input lag will be if you use VGA. This is very important if you play fast(twitch) shooter games.
    Finally, VGA only contains the color information for your monitor's image. DVI includes more than that. That's why when you connect using DVI, you don't have to adjust your monitor's image position, phase, and clock corrections to sync. It contains exactly how/what your video card wants to display.
    If you hook up your LCD with VGA, you will notice that several monitor adjustments become available were they were not under DVI. That is because DVI carries all the information your monitor needs to configure itself where as VGA does not.
    There are many technical differences, but these are the ones that I could remember on the spot. If you have any more questions, feel free to ask.
  3. #13
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by si_romin View Post
    You can also have long cable runs up the DVI max length with no distortion. VGA is analog and susceptible to noise. This is eliminated with digital signaling.
  4. #14
    Jan 2009
    Quote Originally Posted by Fiberoptic View Post
    i can see the point with regards to cable length, but VGA works with no problems up to about 5m, which is a realistic distance.
    i think i need to see a 7 inch monitor running off DVI before i can comment. i believe there is a Xenarc model that does this, but requires quite an ugly external box. What's the quality like with this?
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. CES 2009 - Giantec Single Din Car Computer
    By Fiberoptic in forum Mp3Car Blog Talk
    Last Post: 01-11-2009, 11:58 AM
  3. CES 2009 - Get Superman Vision with FLIR
    Last Post: 01-11-2009, 10:44 AM
  4. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  5. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
Tags for this Thread
