I havent gotten mine yet.. but according to everything I've read I believe there is drivers specifically for the touchscreen functionality... they shoulda been on the driver disc that came with the screen though...![]()
OK, I got the test screens from MP3Car today, I cant seem to get the touchscreen to work on the 730. Are there seperate drivers I need?
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
allright, found a spot that you should be able to get it.
http://www.thegadgeteers.com/product_mimo.html in the right sidebar
"Newer XP/Vista 32/64-bit Touch Driver 1/09" that one should do it.
OK, I found the drivers. It seems to be working. The WebCam and Microphone are useless. The HUB will say that 2 USB devices can not be recognized and installed. I figured its the cam and mic since they arent working.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
makes sense. the hub does say that it doesnt support video and audio devices like webcams, etc if i remember correctly.. unfortunate but still.. wireless touchscreen lcd? sweet.
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
OK, today my little bro is bringing his HD camcorder, so I will start recording my progress. I am still lost on what type of battery to use. I was going to use a Gateway battery because of it small size, but it has like 6 tiny little pins on it, and I dont know what is what.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
Post a picture of the battery, maybe someone here know what pins are what
Use your meter to measure the pins. That is what I did with my 6-10 pin battery. Draw off the connectors that test out as the primary voltage (marked on the battery)
I soldered the end of the wires with a big "ball" of solder on the end.
I used pliers to squash them down until they fit in the connectors.
This in effect made a "custom male spade" connector.
I used a tad of shrink tube up to the makeshift spade to make sure it didn't short on anything.
If this was a final install you might want to block off the unused pins, label stuff, or make a quick release harness using some male/female crimp connectors and a few inches of spare wire.
