Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 71 to 80 of 118
Thread: New Product: p5USB Hub
  1. #71
    Jan 2009
    so you put the m2atx the the ''c'' mode....
    mine was at that mode before(i try some other modes too)...and when the ignition was at ''on'' it was ok..but when i put the ignition at start...the pc restarted,....
    now i am in the recomended mode of the m2atx..and i dont have this problem...but the pc shut down completly after 5 sec
  2. #72
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by summer69guy View Post
    Mine survives crank no matter what. As the M2 should. You sure you have an M2, and not some chinese knockoff?
    1.9in x 2.9in -- 47mm x 73mm
  3. #73
    Jan 2009
    yes i have an m2-atx from mo-co-so
  4. #74
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    The next batch of p5-uSB devices are shipping to us on October 9th. Depending on how long customs takes, we hope to ship these a week or two later around October 16th.
  5. #75
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    P5USBs are back in stock and ready to ship now ;-).
  6. #76
    Mp3Car Staff
    ecog's Avatar
    Aug 2005
    Blog Entries
    11
    Quote Originally Posted by Sonicxtacy02 View Post
    it wasnt any sort of fuse i know about.. there's 2 solder points there.. but unless the fuse combusted it wasnt that.
    And no its not my phone number its my work fax. Everyone feel free to spam it !
    Soooo... anyone know whats supposed to be here? lol
    I noticed (at the car meet of all places) i started getting random disconnects from devices plugged into the P5USB. Today i decided to remove it from my car to see if i could find the problem and this is how i found it. I did test the advertised reverse polarity protection as a part of my review soon after i got it a few months ago, but the problem with the disconnects just recently started. Any ideas?
    lol, so we did some research (and when I say we, I meant Mike) and there is a way to short circuit the P5USB.
    As you know the P5USB includes a reverse polarity protection diode to prevent damage to the P5USB in the event polarity to the input wires gets reversed. As noted by Bugbyte in his review, this feature works well (he initially accidentally mis-wired his P5USB and it was not damaged).
    HOWEVER, if the P5USB in connected to a USB device, which is connected to a computer, which is grounded to the car’s chassis, THERE IS A SHORT CIRCUIT PATH WHICH WILL ALLOW THE BATTERY TO DAMAGE THE P5USB. Here is a drawing of the problem.
    The top drawing shows the correct connection of the P5USB and the protection diode. If the battery wires are reversed, the diode protects the P5USB.
    However, the bottom drawing shows how a reversed battery connection will short through the “ground” wires of a connected USB device that is also connected to a computer that is grounded to the car chassis. Once the P5USB is connected to a USB device & PC, reversing the polarity of the battery will damage the unit.
    There is no way to protect against the short circuit scenario in the bottom drawing. This illustrates the need for a fuse in line with the P5USB so that if the polarity of the wiring is reversed the P5USB is not damaged. It also illustrates the need for installing the P5USB before connecting it to USB devices.
    lol, congratulations sonic you just made it to the top of my list if I need a device blown up, and I don't mean that in a bad way. Finding little use case scenarios like this is really hard. I talked to Stephen about the PM and he'll get back to you.
  7. #77
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Thanks for the support guys... if you need anything else blown up i'm definitely your guy!
    Quote Originally Posted by ecog View Post
    Live mp3Car Facebook Chat
  8. #78
    Oct 2009
    System Crashes Upon Detecting Sound Card or Fails to start up
    Hi guys! I just received my USB hub here in singapore. I need HELP!
    Firstly, my PC (currently on Viliv S5) crashes(blue screen!) when i try to plug in my creative external USB sound card to the hub, or when i leave my usb cable connected and restart my S5 it refuses to start up.......
    What went wrong? The sound card works well with direct connect to the S5. Note- i only have the soundcard connected to the hub.
    the other USB devices works fine - USB 3G modem, GPS works fine.
    Second is 500mA enough to power a external DVD drive? with a single cable connection?
    My ride is Honda Civic FD
  9. #79
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by Jaex View Post
    Have you tried a different cable? Do you have the newest drivers on the sound card? Do you have the latest OS service packs? What OS are you using?
    It depends on the drive. Cheap drives often require two cables.
  10. #80
    Woodbridge, VA
    Blog Entries
    55
    Ugh my last post about this got lost... but creative sound devices generally need to be plugged directly into the computer else they exhibit the behaviors you describe.
    More than likely you will need 2 cables to power that dvd drive reliably. Most of them come with 2 cables for this reason.
  1. disable power to a usb hub?
    By dragons0088 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-05-2009, 07:00 PM
  2. how to use a USB hub
    By toofresh in forum General Hardware Discussion
    Last Post: 01-22-2009, 07:15 PM
  3. USB Hub Doesnt Work On Boot - Help
    By we87 in forum Input Devices
    Last Post: 08-03-2008, 12:12 AM
  4. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 10:50 AM
  5. Replies: 17
    Last Post: 12-02-2007, 03:50 PM
