Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Wireless USB TPMS Review
  1. #21
    riv
    riv is offline
    Dec 2009
    I and folks from my team are willing to volunteer the Linux (nghost) integration. We are doing for some development for this frontend right now, so may try to help on sensors kit.
    Anyway, I am planing to get 2 kits for myself, for 2 cars and until the second one is installed - we can use for the development.
    How many people would be interesting in this?
    The question - if I need to have a kit with 5, what will be the price then?
    Could I purchase just sensors later, if I need to add to spare tires?
  2. #22
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I would like to know if these tpms kits are good for north america regarding frequency of the senders and what is turnaround time for shipping, i have tried to send private message regarding this matter to lok but no reply. hopefully the shipping is not like the replies SNO
  3. #23
    riv
    riv is offline
    Dec 2009
    Finally got the sensors kit, run smooth in Windows.
    So now the question regarding the Linux integration - would anyone did any progress on it already?
    If not - we can put the basic stuff together and share for all, but I would like to see if it is possible to get original TPMS developers help on defining HID interface between the receiver and PC. Possible?
  4. #24
    riv
    riv is offline
    Dec 2009
    Porting the TPMS to Linux. Please help!
    This is what we have discoverer so far:
    Raw Data Buffer
    Byte 0: Pressure Byte (Bar)
    Scaling = 0.025 Bar/LSB
    Zero Point = 0x28
    Formula:
    P = (PB - 40)*0.025
    Samples:
    0x26 = -0.05 Bar
    0x27 = -0.025 = -0.03 Bar
    0x28 = 0.00 Bar
    0x6D = 1.725 = 1.73 Bar
    0x7B = 2.075 = 2.08 Bar
    Byte 1: Temperature Byte (Celsius)
    Scaling = 1 C/LSB
    Zero Point = 0x28
    Formula:
    T = TB -40
    Samples:
    0x2D = 5 C
    0x2E = 6 C
    0x3E = 22 C
    0x40 = 24 C
    Byte 2: Battery Level Byte
    Relative level of battery. I think the range is from 0x00… 0xFE.
    For the manipulation of this byte to actual “V” I need to know lowest battery voltage on which the sensor could work and type of the battery.
    Byte 3: Sensor Mode Byte
    It sounds like this byte represents status of the sensors, as per below table (Sensor Modes).
    NormalMode = 0x01
    Sensor Modes
    http://www.mp3car.com/vbulletin/port...erface-19.html
    Mode Description
    Storage Mode
    If the pressure is below 1.5 bar, pressure is measured every 60 seconds but no data is sent. If the pressure increases above 1.5 bars, the sensor shifts into the Initial mode.
    Initial Mode This mode occurs if the pressure increases above 1.5 bar from Storage mode. In this mode, pressure is measured every 0.85 seconds and data is sent every 0.85 seconds. This sequence is repeated 256 times. After the sequence is repeated 256 times, the sensor shifts into the Normal mode only if pressure is above 1.5 bar. If the pressure is below 1.5 bar, the sensor will shift into the Storage mode.
    Normal Mode
    Pressure is measured every 3.4 seconds and data is transmitted every 60 seconds. If the measured pressure differs by more than 200 mbar from the reference taken every 60 seconds, the sensor enters a Pressure Alert mode.
    Pressure Alert
    It is the same measurement and transmitting pattern as the Initial mode.
    High Temp Alert
    If the temperature exceeds 120°C, the sensor device enters into the same measurement and transmitting pattern as the Initial mode.
    HID Protocol
    To poll a sensor data:
    1. Host writes one byte to device with required sensor number coded as 0x20 + SensorIndex. First Sensor index equals to 1.
    2. Host reads the four bytes buffer from device. Structure of buffer is explained above.
    Please help me to fill the gaps and misunderstandings.
    Dec 2011
    I like it,but i'm in china,how can i get this?
  6. #26
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    from the store.
    http://store.mp3car.com/USB_TPMS_Ver..._p/com-090.htm
    or you can get the TPMS system direct from the manufacturer Third Eye which is based a lot nearer you. And then get the CarPC adapter kit from Dejan
  1. interesting way to install XP on cd-less/floppyless
    By gospeed.racer in forum Operating System Optimization
    Last Post: 11-11-2010, 06:55 AM
  2. QUESTION about M2-160WATT AND X-TREME CARPC
    By kostas_lion in forum Power Supplies
    Last Post: 05-15-2008, 09:50 AM
  3. Generic wireless usb adapter drivers?
    By redls1bird in forum Wireless Communications
    Last Post: 01-12-2008, 06:30 PM
  4. EnGenius EUB-362 Wireless Wifi USB Adapter Review
    By L-U-R-C-H in forum The Review Palace
    Last Post: 09-10-2007, 09:21 AM
  5. Best USB Wireless Adapter?
    By James141 in forum Wireless Communications
    Last Post: 06-25-2006, 01:48 AM
