Results 1 to 8 of 8
Thread: 12v-24v Computer Quick Release Power Cable Kit M2-MTR-5-PWR
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Our new quick release power kit was just put on the store today.
    Feature: Takes unregulated power in and gives you regulated power out all from a single snap in cable.
    Scenario: After a clean install you can easily power your touch screen monitor with clean DC power by just connecting the barrel connector coming from your pc. No cutting into the regulated power source required.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    These could sell decent in the store I would think. I actually have one similar to this already I made it from parts I had here, for the same reason, not to have to open the case to pull the power ect. I put a female plug in the hole in the back of my CarPC case, and hot glued it from the inside. I did it this way as to not have a pig tail or wires dangling out the back of the CarPC when I move it around. I can just plug the male plug into the back of the case, and it locks in place.
    My Fiero Build Thread
    Jun 2005
    Austin, Texas
    So am I understanding this correctly that this does NOT have any regulators? It's simply passing-on the regulated power from whatever PSU you install?
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by ScrapMaker View Post
    There is no regulation or fuses which is why the cable is only 10$. You need to add fuses and regulation yourself.
    This is just a part to help make taking your device in and out of your vehicle easier.
    Apr 2007
    USA
    Is there a trick to getting 12V from the monitor power cable? After it wouldn't turn on my Lilliput 629, even though the Lilliput power cable works, I tested it with my multimeter. It registers -33v or -132v, depending on which way I put the negative/positive meter cables. (Maybe I'm lucky it didn't fry my brand new monitor?)
    I am pretty clueless at electrical things, but I do get a 12v reading for my Lilliput cable.
    Apr 2007
    USA
    Ah, duh. It is just a pass-through, so you have to plug in 2 power wires from the other side.
    When I try to run the monitor power from my M3 ATX power supply, it just shuts down the motherboard. I don't understand that, since I'm hardly using any wattage. But again I'm clueless with electricity.
    When I run the monitor power from a regular PC PSU, it works. Though I get a wavy screen, which may be because the voltage is slightly less than 12V (?). I'm curious to see how it will work when I plug it directly to my car's ignition line. It works fine with the AC wall power plug, and with the cigarette lighter plug.
    Apr 2006
    If the p4 connector is taken up on my motherboard, how could I go about making the monitor barrel plug connector still function? Splice into an extra molex connector?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by Fiberoptic View Post
    SNIP
    SNIP
    Fiberoptic,
    For clarity, you might want to edit the first post... it implies regulated power.
    Cheers
    TruckinMP3
    Read the FAQ!
  1. The legalities of wardriving.
    By PURDooM in forum Wireless Communications
    Last Post: 01-29-2008, 06:26 PM
  2. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  3. M2-ATX Problem - Fan runs but does not boot !
    By Autonator in forum Power Supplies
    Last Post: 11-14-2006, 06:22 AM
  4. quick release power to computer?
    By theheel in forum General Hardware Discussion
    Last Post: 03-15-2005, 10:37 AM
  5. morex car power kit vs. ITPS
    By NaFooEsi in forum Power Supplies
    Last Post: 06-16-2004, 01:51 PM
Tags for this Thread
