What's on line 7 of the sheevaplug.cfg file? Looks like the jtag interface isn't working as expected. Is there a difference in the version being used on the Sheeva vs. the version the openocd expects?
Printable View
IRC channel: #openplug on freenode
Because I'm on a 64-bit machine I had to do it anyway, but you might be served by downloading and building the most recent openocd release - just replace the openocd binary in your flashing directory tree with the one you built, and you should be good to go.
Gary (-;
the problem was me compiling openocd with no ftdi support. Everything up and running now!
Awesome! Is it running better now that you have ubifs on there?
Gary (-;
yep, seems much better. I'm building some packages to put in the linuxice repo as we speak. Hurry and get the obdgpslogger repo back up so I can put that in there as well.
Did you end up finding a way to run video from it? I'm looking for a way to plug in something like a little 7 inch Xenarc or Lilliput.
You can get a USB to VGA adapter, or if you haven't bought a plug yet, globalscale [the same manufacturer as made the plug I reviewed] have a new product called the "guruplug display" that will probably meet your needs:
http://www.globalscaletechnologies.c...g-display.aspx
Gary (-;
Oh, sure. There's lots that would work, just search around a bit. I'd suggest searching the forums on plugcomputer.org for "vga"
Gary (-;
