Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: AFKfest 2009 - Shaun Newman - Car computer install
  1. #11
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    He wasn't flaming you, he was simply being blunt. There is a big difference.
    As far as audio, it really all depends on each user. As Darq says, the best thing to do is get a working system going, then once its all set, try the different sound cards till you find one you like.
    In my experience, I tried onboard audio, that sucked, I then tried the Sound Blaster Live USB card. I was OK with it until I had alot of problems with the card not starting up because of USB issues. I then decided to update my whole setup to 7.1 surround sound. Because I liked the Sound Blaster so much, I upgraded to a Xtreme Gamer 7.1 card. Its a PCI card because I did not want the USB troubles. I am 100% happy with the Xtreme Gamer and glad I made the purchase. I am sure there are better ones out there, but I am 100% happy. Sound Blaster makes it very easy to use their products. So in the end it all depends on what your ears like. What sounds good to you, may not sound good for me, and what sounds good to me, may not sound good to you. We all hear things different, so I wouldnt go by opinions on sound cards.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  2. #12
    Newbie ARN1382's Avatar
    Apr 2009
    well, maybe i misunderstood, if then, I apologize.
    Thank you for the info, I know just the sound card is not the olny thing involved in doing things good, but one of the steps you have to be careful with.
    I though the 3sixty was something like an external sound card, but after some research I understood that, was more than just it.
    REQUIRED HARDWARE [50%]
    CARPUTER INSTALLATION [0%]
    LCD IN DASH FRABRICATION [??%]
    Additional mods:
    KNIGHT RIDER LED MOD:[99%]
    Worklog Album
  3. #13
    Elsewhere
    Quote Originally Posted by ARN1382 View Post
    If you have time to flame on my lack of knowledge will you have some time to answer what IS good sound according to you?
    I've got ~50% hearing loss in one ear, so you don't necessarily want my idea of "good sound". My standards are probably lower than most in that regard.
    Furthermore, sound quality is pretty subjective. Some people are simply more sensitive to audio quality while others are not. I don't know about your level of "audiophile-ness", so I am certainly not one to judge.
    That's why YOU need to run some audio in your vehicle and listen to it. Listen for what you like about the audio quality and what you don't (too much bass, a slight hiss sound, flat mid-range, etc.), then adjust your hardware accordingly.
    You may very well be content with onboard sound straight into an amp. You may want digital signal processing. You may want 5.1 surround. You may only want enough bass to annoy your neighbors.
    If i am asking is because I want to learn something new isn't it?
    I think you're going about it the wrong way, then.
    You need to understand the purpose and function of the 3Sixty line and determine if it something that will be a benefit to your installation and/or your plan, not necessarily where it fits into this user's install.
    It is very possible that this specific setup has a need for a 3Sixty unit, or has some plans for its capabilities that your install does not.
    3Sixty isn't a sound card at all.
    It's a signal processor for car audio.
    How about the Wiki?
  4. #14
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i suggest you do the same as DP has suggested. Hook it up.. and if it sounds as clear as you want and will go as loud as you want you have no need for the 3sixty or any other kind of DSP. The reason i added the 3sixty was simply the signal coming out of my pc was too low, forcing me to ramp up the gain settings on my amps. It STILL didnt get loud enough and i had amps overheating on me to boot. That was 2 years and 3 carPC's ago. Now the only reason i still have the 3sixty in play is because the 10 channel eQ is tuned to my liking and i'd rather not have to change it inside of software. My dg45fc motherboard onboard audio signal puts out more than enough by default
    Live mp3Car Facebook Chat
  5. #15
    Jan 2009
    Quote Originally Posted by DarquePervert View Post
    Sound quality is the abilty to reproduce the original track the most perfectly .
    if you talk about subjective thing...it is just an opinion..somme people want more bas..more vocal...etc...
  1. Replies: 10
    Last Post: 03-14-2009, 01:36 AM
  2. Complete Car Computer For Sale
    By scostell in forum Classifieds
    Last Post: 11-18-2008, 11:32 PM
  3. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
