Results 1 to 6 of 6
Thread: SEMA 2009 - Fuel Level Sensor
    is back. FKA Robert Wray
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Rob Wray from mp3Car takes a look at a self calibrating fuel level sensor. It uses a new technology called variable capacitance to measure the fuel level. Because this reads via voltage, it should be able to integrate with a fusion brain.
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    So you didn't really have him elaborate on self calibrating. Does this mean that perhaps 25% will ACTUALLY mean 25%? For example, in my car, I get 250 miles from full to half, then 100 miles from half to empty. I think that is the big issue with many stock fuel sending units, and "calibrating" seems like it would be something that could fix that?
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Sorry about that, what he means by self calibrating is that it will adjust to whatever kind of fuel you put in. It can work with diesel, gasoline, bio-diesel, fuel with additives etc..
    Jun 2004
    Westminster, MD
    What is the advantage over a stock fuel level sensor?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Different fuels....... its really nothing groundbreaking just something no one has come up with yet - variable capacitance is at least 10 years old commonly used with temperature sensing or other similar environmental sensors. I was pretty sure it was already used in a few modern cars but I could be off about that.
    EDIT:
    Its not as simple as connecting directly to your fusion brain unless it has built in conversion circuitry. Most likely you will need to setup a resistor bridge to measure capacitance.
    Fiberoptic's Avatar
    Jul 1978
    Baltimore, MD
    Blog Entries
    143
    Quote Originally Posted by malcom2073 View Post
    The theory here is you could hook it up to your car computer to monitor fuel levels on your display or monitor them remotely if you can't get them over the CAN/MOST bus for some reason.
    If you have an odd shaped tank like Malcolm i would think you could probably calibrate the sensor to match the size and shape and give you an accurate gallons rating.
    I agree this would need some mild modifications to be readable on a PC but I wouldn't think it would be more than a day of work for an experienced EE (electrical engineer) or software guru.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2010, 01:06 PM
  2. obd2kml Road Trip Visualizations
    By longfeltwant in forum OBDII GPS Logger
    Last Post: 06-08-2009, 01:07 AM
Tags for this Thread
