Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Hardware Review: BoomzBoxHD
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Tom Berry (aka Bugbyte) takes a look at the new BoomzBoxHD, a device used to add HD radio to a mobile PC. This ingenious device will be available on the mp3Car store in the upcoming weeks and proves to be a quick and painless installation. Software for the interface is included. Read the complete review below.
    What is it?
    The BoomzBox HD radio is an HD radio that is controlled and played back through your PC.
    What’s in the box?
    - Boomzbox HD radio
    - USB interface from MJS Gadgets
    - 8 pin mini DIN cable
    - Mini USB cable
    - 12 volt AC to DC power supply
    - Mini CD with drivers and BoomzBox player app
    Description:
    The BoomzBox HD radio is an easy way to add HD radio to your car PC setup. Out of the box, there are two main components, the BoomzBox HD radio itself and a USB interface box. The interface box connects via USB cable to the PC and also via an 8 pin mini DIN cable to the BoomzBox. In addition, the 12 volt power supply connects to the interface box. The setup is very similar to using the mp3Car XM radio adaptor and XM Direct radio except that the BoomzBox's audio is routed via USB into the PC -a very nice touch that makes it simple to manage with front end programs.
    The last connection is the car antenna on the BoomzBox itself. The Boomzbox includes a standard Motorola antenna socket that allows you to plug a standard U.S. car antenna cable into it with no modification (some cars, like my VW Beetle require an adaptor to the Motorola socket). In addition, the BoomzBox includes antenna in and out to allow the user to keep a head unit on the car's antenna as well as the BoomzBox (you'll have to purchase the Motorola cable to do this separately). A very thoughtful addition that many folks will find handy.
    Once connected, installation is a snap. The included mini-CD has the required drivers on it. Just plug the interface box into the PC, load the drivers and check the device manager to ensure that the interface box shows up under the USB devices and also under the COM devices with a port number assigned to it. (If you don't have a CD/DVD drive with a caddy on it, you'll have to download the drivers and software to a USB stick like I did. It would be nice if they came on a full sized CD as many car PC's have slot load drives that can't handle a mini-CD.)
    The BoomzBox HD comes with a software app that mimics a car head unit to control the radio. It includes seek, direct tune, three banks of presets and several different skins to change the look of the app. On initial startup the app scans for the radio. If all is well, it will automatically find it and turn it on the BoomzBoxHD. Specs for the radio were not included with my test unit but to my ears the quality of the sound was very good, although I have to say that I'm no audiophile. It certainly sounds much better than analog FM radio!
    One important feature of the BoomzBox is the USB audio feature. This reduces the number of cables from the box as well as solving the problem of getting the sound into your PC. In addition, I found that when using the RideRunner car front end that the program would seamlessly switch between the radio and mp3 files without requiring any input from the user. Nice!
    I tested the BoomzBox HD with the RideRunner car PC front end program. RideRunner is arguably the most popular car front end and I'm happy to report that it worked perfectly with this program. A simple change to RideRunner's rr.ini file to specify "HDRADIO" was all it took for the program to recognize the BoomzBox. Using the Carwings skin I was able to play and tune the radio with no difficulty.
    What could be improved about this product? There's little to dislike about the BoomzBox HD but I found a couple of things that would be nice to improve. The separation of an interface box and the radio itself makes the product clunky and adds more cables to your car PC mix. With space at a premium in many car PC installations, it would be nice if the interface box was integrated into the radio itself with all cabling internal. I'd be willing to trade a bigger box or even some type of header pin connector system that would allow the interface box to piggyback onto the BoomzBox.
    In addition, the requirement for 12 volt power is, I suppose, necessary but tiresome. With 5 volts on the USB line, it would be nice if the USB power could have been used to run the BoomzBox, eliminating another cable. I'm fairly sure that the 12 volt power runs through the mini DIN plug and powers the BoomzBox rather than the USB interface and it seems like it might have made more sense to put the 12 connection in the side of the BoomzBox as opposed to the interface box.
    I hope that mp3car makes the standard for control of the BoomzBox HD available for hobbyists since the BoomzBox is currently a Windows only device. There's no reason it couldn't work with Linux or OS X since it uses standard Prolific FTDI drivers that make the BoomzBox show up as a serial port device. It would be dead simple for a developer to code up a program that would allow the BoomzBox to work on either operating system.
    But these are all nits, really. If you are looking for an easy way to add HD AM/FM radio to your car PC setup, the Boozbox HD is the product for you. It solves the dilemma that many car PC'ers have of "should I keep my head unit or go with an amplifier?" by providing high quality HD radio reception that is piped into the PC and easily controlled by current front ends.
    The Positive:
    Works as advertised, sounds great, easy to connect to system. USB cable routes sound directly into the PC making it easy to manage.
    The Negative:
    YABB (Yet Another Black Box), requires separate 12 volt power supply for radio, interface box and additional cables add to in car clutter.
    The Verdict:
    Thumbs up! The radio Just Works(tm) and is easy to configure to integrate into RideRunner. BoomzBox software player works well, sounds great, sensitivity of radio is good. The BoomzBox HD comes with a pass through antenna cable connector which allows you to connect it inline with the antenna and keep your head unit connected if you desire.
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    does this work for centrafuse?
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Dec 2009
    i wanted to know the same thing!
    FLAC SFiorito's Avatar
    May 2004
    Ok, I'm ready to order now!! Really like the fact that it's USB audio.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Should have mentioned that it will work in Centrafuse according to MitchJS but I don't have a copy of CF to test it on so I can't confirm.
    Want to:
    May 2009
    connecticut
    Does it work with streetdeck
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    does work with centrafuse and riderunner but does not currently work with streetdeck. Based on personal insight i doubt it ever will
    Live mp3Car Facebook Chat
    Oct 2004
    Israel
    looking good
    anyone know's what will be the price tag?
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Aug 2007
    yeah nice ... cost? I litterally just yesterday got in the mail a second-hand HD radio... *sigh* -- timing is everything.
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    Quote Originally Posted by bougle01 View Post
    There is no reason for it not to, in fact it was created a long time ago to work with StreetDeck. it is just up to SD to make it happen.
  1. Hardware Review: Audiotrak Prodigy 7.1 HiFi
    By durwood in forum The Review Palace
    Last Post: 03-19-2010, 03:50 PM
  2. Hardware Review: 4-Port USB Hub CNX-P5USB
    By Sonicxtacy02 in forum The Review Palace
    Last Post: 12-11-2009, 05:02 AM
  3. Hardware review - scantool.net; OBDlink CI
    By jusjake in forum The Review Palace
    Last Post: 09-14-2009, 03:46 PM
  4. Hardware Review: ElmScan 5 ODB-II scanner with StreetDeck
    By RedGTiVR6 in forum The Review Palace
    Last Post: 08-03-2008, 08:13 PM
  5. Hardware Review: SB Audigy2 NX External USB Sound Card
    By hari-bhari in forum The Review Palace
    Last Post: 12-13-2006, 04:55 PM
Tags for this Thread
