Page 1 of 5 12345 LastLast
Results 1 to 10 of 45
Thread: Hardware Review: BoomzBox HD AM/FM Radio
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    The BoomzBox HD is a USB-controlled AM/FM HD-capable radio tuner.
    The Verdict:
    The BoomzBox HD is just what we’ve asked for in an AM/FM radio. With sound quality that rivals factory head units and an easy straight forward installation procedure, the BoomzBox HD should be your first choice for radio.
    Just released: Price will be $179 on the mp3Car Store soon. Release date still to be determined.
    What’s in the box?
    The BoomzBox HD comes with the tuner box, driver CD, a USB-driven controller box, an 8-pin DIN connector, USB cable, and two power adapters for ease of installation.
    Description:
    The BoomzBox HD is a fully RoHS compliant HD radio tuner built from the ground-up for car PC use. The tuner box is a bit smaller than similar devices on the market. It’s built with a solid aluminum casing to withstand automotive applications. The tuner box has just 3 connections, an antenna input port, a pass-through antenna output port, and the 8-pin interface connector.
    The companion device in the BoomzBox HD package is the converter box. This box converts the signal from the tuner box via the din cable, thus allowing audio to come straight from the USB cable. Competing devices require both a serial/USB connection and an audio output to be sent to the PC. The ease of installation is the highlight of the BoomzBox HD. Connect the DIN cable to the converter box, connect the USB to a PC, and connect power to the green power connector, and the BoomzBox is ready for software. The creators even went a step further by including 2 power options, a brick plug, and a bare connector ready for your unregulated 12v and ground wires.
    The driver CD includes drivers for windows XP/VISTA/7. It also includes a test application to put the BoomBox to use. The BoomzBox is fully compatible with the most popular front-ends like Centrafuse and RideRunner.
    The most important quality in a FM/AM tuner is the audio quality, and the BoomzBox matches the sound quality of units from Directed and Visteon. The HD channels sound as crisp and clear as you could ever want from radio. That being said, the BoomzBox has the issue of HD signals clipping in and out that most all HD radios have. If you can deal with that small issue, the BoomzBox HD is the standard for which future car PC radios will be judged.
    The Positive:
    • High-quality sound in standard and HD modes
    • Easiest HD radio to install on your computer
    • Audio over USB leaves your line-in open
    • Built specifically for car PC use
    The Negative:
    • HD signal clipping is still present
    • Missing the optional Head and remote other HD radios have
    The Verdict:
    Specifications:
    Dimensions (Tuner): 12cm x 7.8cm x 3cm
    Dimensions (Converter): 6.5cm x 6.5cm x 3cm
    Inputs: Motorola Style antenna input
    Outputs: 1 x USB, 1 x antenna output
    Power Supply: Accepts 12v Unregulated
    Jul 2008
    Price?
    Just my 2 cents here... but that price point sounds a bit excessive for radio. I'm sure there are many people like me on this forum, but almost $200 (cost + shipping) for radio is a no go. I was very interested after watch bugbyte's video to maybe install one of these but now my dreams have been crushed. Guess I'll stick to just streaming all my radio content for now
    Oct 2004
    Israel
    i argree with you prodigalsun
    i was very interested in the product
    and by the looks of it i tought it would be somewhere close to 50$
    dissappointing :\
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by prodigalsun View Post
    Well you have to look at the price of an equivalent unit. The Visteon HDZ300 was $150, and I'm sure the Directed was around the same price when it first came out. An extra $30 for USB audio and control I don't think is unreasonable.
    Edit: Wait 3 years, and I'm sure you'll be able to get one used for $50... which is how much you can get a 2-3 year old used Visteon or Directed unit for. I mean.. is that what you're comparing the price to?
    RevFE
    My Shop
    Organic Me
    Heather's Avatar
    Sep 2007
    Fells Point, Baltimore, MD
    Blog Entries
    48
    A note on retail price - This product has been certified by HD Radio and mp3Car licenses the HD technology. This product may not be for every hobbyist, but for those that would like a robust radio solution, mp3Car and Mitch have delivered a solid product at a fair price.
    Oct 2004
    Israel
    yeh thats what i was comparing to
    because for most people radio isn't necassary its an extra feature
    if the price tag lets say was 70$ i think alot more people would have bought the unit..
    i live in israel , we only got fm/am radio ( using mostly fm )
    the 20$ usb dongles just don't get the job done
    so i tought of buying a used visteon/directed for 50$ + 25$ for mitch's cable
    but then i saw the boomzbox review and it looked like a promising , little , cheap , light-weight ( for shipping ) thing
    i see no reason to pay 180$ not including shipping for something i don't must use , you understand?
    im sure mp3car have thier own economic tought , but it seems unreasable alot of people will buy a 200$ radio unit ( even if they can use hd )
    Oct 2009
    Will this easily integrate into Centrafuse?
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by FantaXP7 View Post
    this is CF3 ready thanks to mitchjs updating there hdradio files.
    Live mp3Car Facebook Chat
    Nov 2009
    Mac anyone?
    I am a huge fan of mini mac installs.... I agree that 200 bux is way outta range ESPECIALLY since there is no MAC support.
    They come with mac support and drivers then i'm in for the $200
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I connected the unit to my Mac Mini and tried to run it under Windows using VMWare but kept getting a communications error. The radio showed up in the device manager and also in the USB section but for some reason, I could not get it to work.
    I had a similar problem with the XM radio that uses a similar interface device. I was able to use FTDI drivers to communicate if I used a Kensington serial to USB port and cable but was unable to get it to work with the USB interface.
    Any suggestions are welcome and I'm happy to try them out if you have any.
    Want to:
  1. HD Radio
    By pcullin in forum Car Audio
    Last Post: 09-01-2008, 12:31 PM
  2. Replies: 37
    Last Post: 07-14-2008, 03:02 PM
  3. Which EQ for HD radio?
    By ccrum in forum RR Skins
    Last Post: 06-24-2008, 11:26 AM
  4. Phx Area HD Radio Question
    By 99WhiteSleeper in forum Car Audio
    Last Post: 06-23-2008, 12:27 PM
  5. TV & AM/FM Radio Hardware Suggestions?
    By Chita79 in forum General Hardware Discussion
    Last Post: 02-01-2005, 07:22 AM
Tags for this Thread
