Results 1 to 2 of 2
Thread: Software Review: Centrafuse 3.0 Auto Navigation
    Mar 2006
    Blog Entries
    Centrafuse Auto Navigation 3.0 review
    What is it?
    A front end software that sits on top of Microsoft Windows, an interface between you and your car's infotainment. It allows you to play music, watch videos, assist in GPS navigation, listen to satellite radio, communicate with your bluetooth cellphone, respond to voice commands, display rear view camera, multiple media zones, etc. With it's strong emphasis on making it easy for programmers to make plugins, it can be used for controlling anything that's attached to your carpc through one common interface.
    What's in the box?
    I didn't receive a box or anything physical for this review, just an email message from with a serial key and where to register/download. I downloaded the software from and registered my carpc hardware ID to it. A quick start PDF manual can be found after installation. For more documentation see the FAQ on their forum.
    Test machine:
    Intel D945GCLF2 dual core 1.6Ghz Atom processor, 512MB ram, 80GB Seagate EE25 Automotive HD 5400rpm, GPS BU-353, Windows XP
    Setting up:
    Installation starts by visiting and creating an account (not to be confused with the forum user account). Select the link called "Looking for your 2.0 licenses?". It will give you a link to download the 3.0 software by clicking on the "Get Installer Files". This is also the same web screen you use to register your hardware ID -- more on this later.
    Before you install Centrafuse on your carpc, I'd highly recommend reinstalling a full copy of windows if you plan on using voice control. My previous install of TinyXP windows edition didn't allow voice control to function. If voice control isn't important to you and you want to continue using TinyXP, then you must enable "Windows Management Instrumentation" service for hardware ID to function properly.
    Installation is straight forward click on Centrafuse_30_1106.exe. It first installs microsoft's framework 2.0 and SP1, reboots Windows, and restarts installation again. Next it will ask if you want optional voice control and blue tooth to be installed before finally installing Centrafuse. Next step was to install the GPS navigation portion by clicking on Centrafuse_NA_30_part1.exe, installation took a while but it required no further reboots. Software installation total time was eight minutes. When you run Centrafuse for the first time, it will inform you of your hardware ID. Write this down and visit again to obtain a license. Centrafuse will email you a license file that needs to be copied to "\Program Files\Centrafuse\Centrafuse Auto".
    Centrafuse does so many things so I figured it would be best if I'd make a short 17 minute video exploring what it does.
    The screen shots from centrafuse are much better than mine, so I will link you to them:
    The Positive:
    - Extremely touch screen friendly with large buttons, you do not need a mouse in your car.
    - Bluetooth cellphone interface
    - GPS navigation lowers volume progessively before announcing next turn.
    - Configuring the software is straight forward and very easy to do with it's nice GUI interface. No confusing .INI files to edit.
    - Changing the current song to another is very easy to do without disrupting your current screen. For example, you're entering in an address in the navigation window and suddenly there's a song you don't want to listen to. No problem click on a music button and you can quickly switch to another song, click on the button again and you're back to where you left off undisturbed.
    - Customizing the default skin can be modified easily if you want to rearrange some of the menus.
    - Voice control works well, although I couldn't request a song by title (someone would need to write a plugin)
    - No unexpected crashes, works well.
    The Negative:
    - GPS navigation has many disappointments: Maps are dated from 2007. North america maps are divided into 10 regions making things cumbersome, for example, you cannot select a destination to Detroit, Michigan from Windsor, Ontario because they're on different regions. Selecting gas, food or hotel points of interest don't work if your map is set to Canada (bug). GPS navigation didn't work after immediately configuring the GPS device, had to restart centrafuse for the new settings to take effect.
    - My loading times are a bit slow 25 seconds from a cold start, or 14 seconds on a reload. My other front end softwares load up in about half the time.
    - Memory useage has been 153 to 160 MB, about triple to what the other front end use. This higher memory useage directly influences in longer hibernation read/writes. Approximate two seconds longer hibernate resume.
    - No gestures feature -- a minor inconvience
    - Surprised to see a slight pause between main menu screen changes, this either suggests I need either a more powerful graphics card or better CPU as the popular dual core atom never showed any weakness till now.
    The Verdict:
    Buy the software without GPS navigation and use a third party GPS navigation software. With the multitudes of plugins, integrating third party GPS software is easy and works well. Loading times are the longest I've experienced with any front end software but this won't be much of an issue if you use hibernation or suspend. If you don't have the time to make those other front end work correctly and just want something that works with support then I highly recommend you go this route. I like to thank mp3car and Centrafuse for this opportunity to make this review.
    Minimum: 1GHz processor, 256 MB RAM (note: my system required 351MB for Windows XP + Centrafuse 3)
    Recommended: 1.5GHz processor, 1 GB RAM
    Mar 2006
    Blog Entries
    Note: Near the end of the video I mistakenly assumed "main menu" voice command would take me to the first main menu screen. When I watch the video you can see the screen changes and goes to main menu. I should have asked for "next song" or something else.
  1. Review: Garmin MobilePC Windows Navigation Software
    By Fiberoptic in forum The Review Palace
    Last Post: 07-19-2009, 01:30 PM
  2. Open Source offroad navigation software
    By JuniorGeezer in forum GPS
    Last Post: 02-22-2009, 12:22 PM
  3. Navigation software that runs SMOOTH?
    By briderx in forum GPS
    Last Post: 09-05-2007, 07:56 AM
  4. Replies: 36
    Last Post: 04-13-2005, 05:03 AM
  5. gps navigation software
    By llmask in forum GPS
    Last Post: 10-26-2003, 02:00 PM
