Seberry
Of the 2 pics you posted, post #22, the XF700 screen is the clear winner, but in my opinion there is still way to much glare for a high end product. You can see the persons hand on the screen clear as day. The pic on the left has a cheap touch panel which is why it looks milky. The XF700 has better AG/AR coatings on it which is why it is clearer. It is the quality of the touch panel that determines the % of light transmission and clarity of the picture. A 4 wire resistive panel can be just as clear as a capacitive panel. We have even sampled some 99% clear 4 wire panels.
Again no matter what with a non bonded panel you will always have some reflection and washout/loss of contrast. Below is a link that shows you the difference. As you can see the stock panel will only reflect a maximum of 4% of the light , but look at how bad the picture quality is. It might not sound like much but as you can see a 1-2% reflection change makes all of the difference in the world.
http://www.mo-co-so.com/v/~photos/Op...percentage.jpg
Our monitors are crystal clear and have no milky appearance.
Also remember when you are buying a Transflective monitor that Transflective is a generic term that means the monitor has been modified to be easier to read in sunlight. There is no specific standard that a monitor or company has to adhere to call a monitor Transflective/Sunlight/Daylight Readable. Bonding is a very expensive process that requires a lot of pre testing of the hardware to make sure it is defect free. If a monitor is bonded the company selling it will specifically mention it. If the answer is we don’t know or we don’t discuss the specific technology in our products the answer is no! The secret is what bonding material you are using, what you are bonding and how you are curing the bond, not if it is bonded or not.
Also good call on asking Samse for pics of different angles. Having taken hundreds of pictures of these monitors I can tell you it appears they are trying to use deceptive angles and or photo shop to boost the look of the monitor. The top pic as you noted is taken from a side angle and the comparison pic just doesnt look right. Its like they took the glare off the entire picture. If those housings were in direct sunlight they would appear much lighter in color. Just look at the pic above it. The case looks almost grey from the light hitting it. You will notice in the 2 links I posted all of the pics were taken straight ahead, not at an odd angle to minimize the glare. The sunlight hitting the pics is coming in through an untinted window from right to left to simulate what you would have in a car.
