Oh snap! I'd love to tap into the already existing antenna. Will existing scantools work?
A clever engineer over at radioetcetera has released code to convert Onstar / GMLan bus to plain NMEA data. There is a little bit of work left to be done, but it looks like most of the heavy lifting has been completed. Why would you want to do this?
- GM has put a great external GPS antenna in your car. Why do you need to buy another one?
- It is fun weekend project and a great exhibit of your geek talent
- Using an external GPS should give you much better reception
All someone needs to do is make a single wire CAN to RS-232 adapter and tweak the provided code to finish the project. The guys over at hack a day say Andy is having a baby and has to stop working on the project. Maybe some mp3car CAN gurus could pick this up? We might consider issuing an innovation grant if cash is an issue. Let the discussion begin!
Former author of LinuxICE, nghost.
Current author of nobdy.
I don't know. you might want to check that guys blog. If an existing scantool did work, that might be a great reason to buy a scantool with a gm car - you get engine diagnostics and GPS all with one purchase and one cable.![]()
That's great! That means it can be implemented in software for those of us with existing scantools. I'll see if I can come up with a plugin for obdgpslogger or something. I can test on my 08 impala.For hobbyists, you can use CAN to RS-232 converters such as the CAN232 or the OBDLink, but you’ll probably need to log the data and post-process it.
Make sure you use a scantool that supports SWC.
SWC = Single Wire CAN = separate network from regular 2-wire CAN.
My Elm327 Bluetooth doesn't support SWC![]()
I did some digging (Cause I wana play with this!)... The single-wire stuff has a few names - GMLAN, Class B, class 2 data bus, J2411 SWC Single-Wire CAN.
I'll be darned if I couldn't find a single PC adapter that can tap into the SWC network for less than $500! Some of them were $1100+I'm taking a little break from googling this topic so If anybody can find a cheap (less than $50) interface for SWC please post it
I was able to use a two-wire CAN adapter (sort of anyway) by tying CAN_LO to ground. I did get a lot of error frames while doing this, but was able to see the data.
Also, some of the GM CAN protocol documents can be purchased here:
http://auto.ihs.com/news/newsletters...r05-04.htm#gmw
I'm not sure if they contain any useful information or not, I haven't seen them.
Andy
Andy - thank you for the guidance.
I wonder if one might have luck with an ELM327 based chip...
On power-up, the ELM327 checks to detect which pinout/protocol it's connected to... So one would may need to manually run ATSP to set the protocol and bypass the autodetect. (Which protocol/rate??)
With all that said and done, ATMA (monitor all) would be used to sniff the network.
I wonder if regular OBD MODE/PIDs can be requested on the SWC network, or is this connection only feasible for sniffing purposes...
References:
ELM327 Datasheet
ELM327 Bluetooth Adapter (Chinese knock-off)
Protocols supported by ELM327:
0 - Automatic
1 - SAE J1850 PWM (41.6 Kbaud)
2 - SAE J1850 VPW (10.4 Kbaud)
3 - ISO 9141-2 (5 baud init, 10.4 Kbaud)
4 - ISO 14230-4 KWP (5 baud init, 10.4 Kbaud)
5 - ISO 14230-4 KWP (fast init, 10.4 Kbaud)
6 - ISO 15765-4 CAN (11 bit ID, 500 Kbaud)
7 - ISO 15765-4 CAN (29 bit ID, 500 Kbaud)
8 - ISO 15765-4 CAN (11 bit ID, 250 Kbaud)
9 - ISO 15765-4 CAN (29 bit ID, 250 Kbaud)
A - SAE J1939 CAN (29 bit ID, 250* Kbaud)
B - USER1 CAN (11* bit ID, 125* Kbaud)
C - USER2 CAN (11* bit ID, 50* Kbaud)
Ok, so I guess the ELM327 doesn't support a 33.3kbps mode. That's probably out then.
Someone could look into whether GPS info is available on the regular OBD or powertrain CAN busses that run at 500k. I can't think of a reason off the top of my head why they might put it there, but you never know.
Andy
