Results 21 to 30 of 36
Thread: USB Powered Touch Monitor by MIMO, UM-70C
  1. #21
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Yes it can be your primary monitor. It just will NOT show your bootup sequence. The OS has to recognize it as a monitor, the bios will not.
    I know from what i tested on my mac i was able to make it my primary.
  2. #22
    Jun 2009
    Thanks. I'm going to wait for a more detailed review to come out. It's definitely interesting.
  3. #23
    Mar 2010
    OSX? Any one know or worked with either of these under OSX?
    Hey there.
    Has any one know or worked with either of these touchscreen under OSX?
    Ideally I'd like to have 3 or 4 all working at the same time...
    I know they say they're supposed to work, but I want some hands on feed back if possible
    Anyone?
  4. #24
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    3 maybe if you don't have any motion or video..... 4.... definitely not
  5. #25
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    If I can get 4 people to pre-buy the mimo monitor, I can test the 4 on a single computer on video for you guys to see the results. If you do want to do that, when you buy the monitor put in the order notes "I am pre-buying this monitor so it can be tested"
    I'll do the test if I only get 3, but 4 would give us the answer.
  6. #26
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    What about just two? Where you able to test that?
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
  7. #27
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    I only can open 1 for testing, I can't open other people's monitors unless they give the ok.
  8. #28
    Apr 2010
    fps and response time?
    has anyone used one of these USB monitors for any 3d games? i'm curious what FPS rating you can get at the native resolution. seems like it could be pretty lousy even with the low resolution, since it's probably just software accelerated. any ideas?
    similarly, i'm wondering if anyone knows of the response time ratings for these 7" lilliput panels.
  9. #29
    Feb 2010
    Talking
    Quote Originally Posted by NoTec View Post
    There isn't much info in this review. It basically is telling you that this product exists, how it works, and its cool.
    How is the video quality?
    What res' does it run?
    How sensitive and accurate is the touch screen?
    How would this work as a primary monitor?
    Examples of all of these questions?
    How about some good information we can use?
    Would like those questions answered, you gave the minimal information which is not enough interest someone.
  10. #30
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    - if run in its native 800x480 res its clear and crisp. Video playback over USB is a little choppy.
    - 800 x 480 is native and best
    - its resistive, so its not very sensitive, but if you do the 25 point calibration its really accurate
    - for a desktop or car pc you could use this as a primary, get it installed first, then reboot with only this plugged in. You will only start to see video once you get to the windows login screen, you won't see anything for bios or while the system is booting
    - i will have examples soon. My apologies for not having any atm.
    - the sky is blue during the day because of light reflecting off nitrogen gas and the wave length of blue light is shorter and gets abosorbed and reflect to our eyes.
  1. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  2. Powered USB Hubs?
    By Booger in forum Power Supplies
    Last Post: 06-09-2007, 09:21 AM
  3. Non powered USB hub
    By ComradeJew in forum General Hardware Discussion
    Last Post: 03-05-2007, 03:12 AM
  4. I'm Confused about Opus & USB still staying powered
    By Troy McClure in forum Power Supplies
    Last Post: 10-27-2004, 09:59 AM
  5. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 03:35 PM
Tags for this Thread
