Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: USB Powered Touch Monitor by MIMO, UM-70C
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Embed this video
    MIMO uses DisplayLink technology to make the 720-S, a 7 inch monitor that has 3 uses for the single USB cable. It gets power over USB, video over USB, and touch input over USB. There are many possible uses for this kind of monitor where any program that has multiple windows, could be spread out to this extra monitor.
    Constant Bitrate NoTec's Avatar
    Jan 2009
    South Florida
    There isn't much info in this review. It basically is telling you that this product exists, how it works, and its cool.
    How is the video quality?
    What res' does it run?
    How sensitive and accurate is the touch screen?
    How would this work as a primary monitor?
    Examples of all of these questions?
    How about some good information we can use?
    Jun 2007
    St. Louis
    Doesn't look very bright either. I can't imagine it being able to be as bright as other monitors being as it gets it's power over usb which is limited to 5v 500mA. The LED backlight in the lilliput eby701's probably uses more than that alone.
    Apr 2009
    Newark, New Jersey, United States
    can i connect this to a 15m usb cable?
    my pc is in the trunk...
    would the length of the cable affect the power needed?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    displaylink advertises 10 usb monitors per computer but realistically your limited to 2 for multimedia.
    display res is 800x480 but higher res is supported (just no real advantage).
    I have yet to see a touch screen that isn't accurate.
    No it can't be used as a primary monitor-you lose access to the bios. But if you don't mind that then yes it can.
    Send me one....ill write a full review
    Jul 2006
    LI, NY
    USB does have signal strength issues at some point, but U can just buy a chord that has a boster in line, and it'll work
    Dec 2008
    Quote Originally Posted by trinybwoy View Post
    i would think you can use a shorter cable then that, i dont know too many cars that are 45 feet long!
    Apr 2009
    Quote Originally Posted by trader007 View Post
    lmao 3m/15feet
    lol
    i should have proof-read my post
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I would like to use them as headrest monitors. But then how well would they play multimedia?
    Dec 2007
    Danville, CA
    Yeah, somebody must test this. I just checked at the store, not much more info.
    Does it work well with resume from hibernation? What about hybrid sleep with windows 7? Does it play blu-ray movies (certified drivers for that). Is there an option to feed real power, and use the USB just for data? (I mean, how bright can this be from usb only?).
    I'd buy two to use in my headrests, if I had good answers for all those questions. I'd hate to have to unplug and plug them again for it to work after resume (as I've heard it can happen to other USB monitors).
  1. USB self powered hub, which one
    By htsource in forum General Hardware Discussion
    Last Post: 07-26-2007, 04:31 PM
  2. Powered USB Hubs?
    By Booger in forum Power Supplies
    Last Post: 06-09-2007, 09:21 AM
  3. Non powered USB hub
    By ComradeJew in forum General Hardware Discussion
    Last Post: 03-05-2007, 03:12 AM
  4. I'm Confused about Opus & USB still staying powered
    By Troy McClure in forum Power Supplies
    Last Post: 10-27-2004, 09:59 AM
  5. 7" touch overlays with usb controller any interest
    By pogue1000 in forum LCD/Display
    Last Post: 01-14-2004, 03:35 PM
Tags for this Thread
