Results 1 to 10 of 18
Thread: Hardware Review: XoByte miniSpark Startup/Shutdown Controller
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    What is it?
    The XoByte miniSpark is a startup and shutdown controller that uses Wake-On-LAN capabilities to handle startup and shutdown of your laptop or PC.
    The Verdict: If you use a laptop or netbook as your car PC you should own a miniSpark. The people at XoByte have seemingly created the perfect solution to handling the startup and shutdown of a computer and it's associated accessories in the car. The one thing that impresses me the most is the control it gives the user, all while using only your LAN port and saving a precious USB port.
    What's in the box?
    The XoByte miniSpark comes with the main controller box, a 6-wire connector, and a pair of automotive fuse adapters for 12v power.
    Description:
    The XoByte miniSpark is a powerful device which allows control of a netbook,laptop, or personal computer's startup and shutdown capabilities through Wake-On-LAN technology. The real power in the miniSpark comes from the user's ability to control its various functions all from within the miniSpark Configuration GUI. This tool is compatible with Windows computers running XP or higher, and allows even beginner users to control the miniSpark's functions with both ease and simplicity.
    After a brief period in which the miniSpark checks to see if the device is connected, the GUI is presented. The top left box in the GUI is nothing more than a set of status indicators which give you the real-time view of each of the 2 inputs and 2 outputs of the miniSpark. If a WOL shutdown event occurs the miniSpark GUI will display the system status on the LED images and also via a pop-up which counts the time remaining to shutdown.
    The bottom left gives users the ability to use either of the 2 inputs to run the appropriate user-configurable shutdown command with the shutdown and startup delays specified. As if the basic settings weren't powerful enough, XoByte allows configuration of both outputs independently. This allows one miniSpark unit to individually shutdown and power up 2 different devices with there own unique settings. For advanced users this capability is invaluable because you can control things like USB hubs, lighting, and other self-powered devices independently of the PC. Each output can be controlled with either included inputs or totally manually through the miniSpark configuration utility. The outputs can also be delayed at startup or shutdown after the PC has been started or shutdown. The ability to set your pulse-width for outputs and to set repeating triggers means the XoByte miniSpark is as flexible as you will ever find a shutdown controller to be. There is even an API available which allows the control of the miniSpark configuration utility to be harnessed in a user-selected front end.
    Despite the flexibility of its software setup, the miniSpark is just as easy to install as any other automotive power supply. Because its not a fully-functional power supply, the miniSpark's red power wire can be powered through an 1-amp automotive fuse. XoByte was even kind enough to include a set of automotive fuse adapters so you can just plug into your vehicles fuse box to power the device. The black wire as in most cases is the ground. The white and green wires are input #1 and #2 respectively, and would in most cases be connected to the automobiles accessory or ignition lines. Should you only wish to use a single input the green wire can be ignored. Lastly, the brown and blue wires are #1 and #2 output wires. PCs that are not "magic frame" WOL capable will need to use one of the outputs to power on the PC through the ACPI lines.
    Once wired, the XoByte miniSpark hardware is ready to go. The only other notable feature would be the single green LED which shows the status of the miniSpark through a series of blinks.
    The Positive:
    • Small hideaway box, but so much power and control capabilities
    • Allows startup/shutdown control without opening up a laptop
    • Uses WOL technology, saving a USB port• Efficiently runs on less than 1 amp
    • A simple GUI which continues to be updated with more control features
    • Ability to control multiple accessory outputs with multiple individually controlled inputs
    • API available for front end integration
    The Negative:
    • Windows XP+ only
    • Computer must be WOL "Magic Frame" capatible for WOL use
    The Verdict:
    If you use a laptop or netbook as your car PC you should own a miniSpark. The people at XoByte have seemingly created the perfect solution to handling the startup and shutdown of a computer and its associated accessories in the car. The one thing that impresses me the most is the control it gives the user, all while using only your LAN port and saving a precious USB port.
    May 2010
    Sounds interesting...
    What's the price tag me wonders...
    Jul 2005
    Does this do something different than the Carnetix P2140 in relation to startup/shutdown?
    Jul 2008
    Quote Originally Posted by loneferret View Post
    http://store.xobyte.com/product_info...c2a2234e287a75
    Jul 2010
    Alright So i have been searching and stuff.
    This device seems like a good device
    But
    is this all i need as far as power is concerned?
    Or i will need to get a DC to DC converter too.
    Jan 2008
    no, this will only tell the pc to turn on/off IF your pc supports Wake On Lan. if it doesn't support it, this will not work at all on your pc.
    you will still need a way to power the pc (dc-dc, dc-ac-dc, monkeys in a wheel, etc...).
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    VENDOR - XoByte M3Sharif's Avatar
    Jun 2009
    Long Island, NY
    Quote Originally Posted by soundman98 View Post
    Well if your PC doesn't support Wake-On-Lan (WOL) you can still use one of the two outputs from minispark as an ACPI signal that toggles the power button on the PC. This would mean that you have to crack open your computer and connect this signal to the ACPI header on the PC motherboard.
    Definitely not as elegant as WOL but it will give you all the same configuration options that miniSpark provides for Powering On/Off. You are correct that the PC has to receive power from another source. miniSpark is a StartUp/Shutdown controller not a power supply.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by Reble View Post
    But
    You could use the laptops DC Cigarette light adapter, perhaps hardwired?
    It's a good device, but I find it a a bit too expensive for me.
    Sep 2010
    Binghamton, NY
    MiniSpark
    Has anyone else actually purchased and used this product - everything I can find is reviews from months back.
    I received the MiniSpark unit and set it up as described in the instructions... and ran thru the troubleshooting described in the instructions.
    The 3 computers I've tried it on all fail to discover the device, the green light does blink the way it's supposed to but there's apparently no link - computers all report network cable unplugged and no lights on the NIC interfaces (should the lights on the NICs light up and blink as if plugged into a normal hub/router?).
    I've also tried multiple known-good ethernet cables. I did test the NIC by plugging it directly into my router and it connects fine.
    I'm assuming I have a defective device but I wanted to post here first (I also emailed Xobyte support yesterday, probably too soon to expect a response) to see if anyone had any thoughts of anything I could be missing.
    Thanks!
    Computer: Windows 7 Ult 32bit
    Acer Aspire notebook
    (This is my first post but I've been lurking here on and off for years)
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by SupraDan88t View Post
    Thanks!
    are you sure you're computers are WOL compatible and WOL has been enabled in the bios?
    Live mp3Car Facebook Chat
  1. BMW E60 install and I-Bus retrofit....tricky
    By Craggy in forum General Hardware Discussion
    Last Post: 11-17-2010, 05:06 AM
  2. Hardware Review: OBDLink by Scantool.net
    By Moysie in forum Mp3Car Blog Talk
    Last Post: 12-23-2009, 02:15 PM
  3. XoByte miniSpark™ StartUp/ShutDown Controller
    By M3Sharif in forum VaultWiki
    Last Post: 07-16-2009, 07:50 PM
  4. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 09:02 AM
  5. OPUS startup/shutdown controller problem...
    By rbarr110 in forum Power Supplies
    Last Post: 11-15-2003, 12:38 AM
Tags for this Thread
