Results 1 to 8 of 8
Thread: Secure Print Start Fingerprint Car Security System Review With How-To Video
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    What is it?
    The SecurePrint Start Fingerprint Security System is a car security device which allows engine starting and vehicle access to be controlled by fingerprint identification.
    The Verdict: The SecurePrint Start Start At Once Fingerprint Car Security System is a great solution for individuals or companies looking to add additional security to their vehicles. Once installed, the system seamlessly integrates and effectively protects a vehicle from theft. However, the system is not designed to replace components already installed if the vehicle for starting.
    The SecurePrint Start system is available now at the MP3Car store
    Embed this video
    What's in the box:
    The SecurePrint Start system consists of the main brain box, a fingerprint scanner, a dialpad, 2 wiring harnesses, a voice-command speaker, an instruction manual, and a wiring guide.
    Description:
    The SecurePrint Start Fingerprint Car Security system may just be the answer for someone looking for added security for their vehicle. The system clearly goes above the standard OEM car security featured in most cars today. With the power of fingerprint technology, the SecurePrint Start system deters anyone from stealing your vehicle without your clear consent.
    I was initially surprised at the ease of installation. Most self-installed security systems come with hardly legible, confusing instructions and wiring diagrams. The SecurePrint Start system however is pretty much a breeze to install. The wires are clearly numbered, and the wiring guide uses the numbers to show where each wire needs to go. There is some factory wiring you need to cut, specifically the wiring to the starter, fuel pump, and vehicle ECU, but this is standard fare with do-it-all systems. You certainly don’t have to have a Master’s degree in electronic engineering to install the unit into the vehicle. The configuration of the system once installed is easy as well. The system uses the combination of the fingerprint scanner and the accessory dial-pad to allow users to enter new fingerprints. Each entry on the dial-pad is greeted with a loud and clear (yet somewhat disturbing) voice confirmation through the systems included speaker. This system is infinitely more efficient than the trial-and-error or dip-switch type systems I’ve installed in the past. At an estimated guess, I would say it would take the average DIY installer no more than 2 hours to wire and configure the entire system. A video showing the ease of fingerprint enrollment can be found below.
    Once installed, the system is activated as simple as pressing your enrolled finger into the fingerprint scanner. In my testing it took less than a second for my finger to be identified and the vehicle to start. Unfortunately, it takes far longer for me to reach into my pocket, take out my key, and turn the ignition. Yes, you still need to do this in order for the SecurePrint Start system to activate. A friend had mentioned perhaps tucking the ignition cylinder away with the key in it, but this is not feasible because the unit depends on removing the key to turn the engine off. Once the vehicle is started the SecurePrint Start system is completely passive. You will still need to use your keyfob for vehicle entry, so people looking for an easier alternative than the factory systems today should look elsewhere.
    The SecurePrint Start system allows up to 9 different enrolled fingerprints and 3 different categories for users, so multiple drivers, families and fleet vehicles can all enjoy the benefits of added security.
    The Positive:
    • Added peace of mind from an additional layer of security
    • Easy to install
    • Voice guided configuration
    • Limits access to vehicle and Car PCs
    • Cuts power to fuel pump, starter motor, and ECU
    • Fingerprint scanner easily molds into most vehicle dashboards
    The Negative:
    • Does not replace vehicles factory ignition
    • Length of proprietary cables limits installation flexibility
    The Verdict:
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    This is pretty cool. Only things I hate is that the keypad looks very dated, the wonna be robo cop voice isnt nice, and you still have to use the key! I also wonder how this thing will play with other alarm systems.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by ZX1Cruizer View Post
    yes the keypad does look ancient but its a tuck-away type thing. The only reason you really need to ever use it once you've got the "regular" users enrolled is taking your car for service (to disable the fingerprint scan).
    The device should work just fine with aftermarket and OEM alarms. The same factory triggers and horns are used.
    Live mp3Car Facebook Chat
    Nov 2009
    Does it incorporate temp & pulse sensing?
    Even though such scanners make me wary, those without life-sign checks scare the crap out of me!
    Sometimes voice recognition is the best, though they always require a backdoor (fall-back method).
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by OldSpark View Post
    I doubt temp and pulse are factors. It says nothing about them in the manual and to be honest There's only a 500ms reading of the finger before the vehicle starts. I DID try to "Mythbuster" the scanner by doing the old fingerprint tape trick but it didnt work lol
    Nov 2009
    You just cut their finger off.
    And since you don't know which one, you cut of all 8 fingers, & the 2 remaining digits.
    That's why I like them. Not.
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    man this thing is expensive
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    I saw one on ebay a couple weeks ago for a couple hundred bucks, thinking about getting this for my ride, no way I'm paying full asking price
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
Tags for this Thread
