Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: AFKfest 2010 - Marie-Jessique Ford F150
  1. #31
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    lots of cool and interesting stuff in this install, if they found someone with some fabrication skills to help clean up the install it would be very impressive
  2. #32
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by JohnWPB View Post
    What will make a huge difference in the sleep state you are using. I is if you are using S2 (CPU, Fans, USB and motherboard are still powered for the most part) or S3 where just the memory is given enough power to sustain a sleep mode. Of course your power supply will eat a little juice in either case.
    Download Sleeper and run it on your machine. (Very small and free piece of software). It will report what sleep modes your motherboard supports. If you do not see S3, then go into the BIOS and check for an option to enable S3. I have found with a couple motherboards here that they default to S2 in the BIOS, and you have to set it to S3.
    For hibernate, that really depends on your graphics card drivers, strange as it may be, as well as enabling it in system properties.
    It does have S3.... So I guess thats what I will go for.
    Quote Originally Posted by Sonicxtacy02 View Post
    I have instant on on my dual core carPC and a SMALL power cell(Kinetik HC600). Depending on the specs of your system, it shouldnt be THAT difficult to get instant on in your setup.
    And for what its worth, these days the yellow top is no better than the red top in terms of floor voltage. The Red/Yellow are now essentially the same in that regard (Optima went cheap). Save your money and go red, or go even cheaper and get a kinetik power cell.
    I was actually looking at that. i was like the specs are exactly the same. I will check out the kinetik batteries. The setup will be a 3 battery setup. One for engine, and the rear 2 for the PC install. Turns out, me redoing my setup allows me to fit 2 of them now and still have room left over.
    Thanx for your guys help.... i dont want to thread jack anymore....
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #33
    Sep 2010
    Show more functionality
    I really appreciate the videos that you host from them various shows that feature vehicles with unique or outstanding MP3car systems. Why don't you ever walk a bit through the functionality of these systems? Isn't that what its all about anyway? Please in the future try to show more of how a system works instead of glossing over the review with a laundry list of items installed.
    Just a beginners thought.
  4. #34
    Jan 2009
    Naples, Floridaaaaaaa
    Systems upgrade
    In the past 2 months, we've kept busy upgrading a lot of the things that were not quite finished when we showed at the AFK fest;
    1 - we upgraded the relay boards with an Advantech I/O robotic module.
    this provide us with 8 relay ports plus 8 digital inputs as well. I am oversimplifiying the ability of this device, but it does some amazing stuff. I have it also driving a servo controller.
    2- We upgraded the wiring for the secondary battery system. The lesson is, when doing the big 3 for one battery, do it for all batteries!!!!
    3- upgraded the scottchy diodes to 40 AMPs we had one of them oriented the wrong way....bad feedback loop. test, test, test !!!!!!!
    4- Added a 400 watt power inverter.....just to keep handy.
    5- Upgraded the audio crossover and moved the stereo system to the bottom of the console; installed a Lilliput touch screen on the top 2 dins, where the stereo used to be.
    6- uphostered the back seats to match the front corbeu seats.
    7- Added a manual battery cutoff to manually isolate the batteries.
    8- bought a pico projector to experiment with heads-up displays. Preliminary tets are prommising.
    9- Finally we got around to upholstering the center console.
    By no means are we done.....
    The low budget model ! 2005 F-150
    • -Custom fiberglass console, CB,Interfaced OBDII
    • -In-dash multimedia w/ bluetooth
    • -Piconet PAN & Wifi Edge internet
    • -Advantech relay board, Pololu microcontrollers w/servos
    • -Embedded Axim palmtop w/backup GPS
  5. #35
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by SaiLong View Post
    Where did you get this board?
    I feel you on that one haha
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #36
    Jan 2009
    [QUOTE=PaulF;1417539]Where did you get this board?
    Advantech
    http://www.advantech.com.tw/products...A44B544AE.aspx
    .... but once in a while one goes on sale on ebay
  1. Need to find 12v (ACC) for 2010 Ford Escape
    By JasonMK in forum Newbie
    Last Post: 08-19-2010, 12:50 AM
  2. Ford Sync New Features with Twitter, Pandora - CES 2010
    By Heather in forum Mp3Car Blog Talk
    Last Post: 02-04-2010, 12:27 PM
  3. Replies: 6
    Last Post: 04-30-2009, 09:05 AM
  4. 2006 Ford F150 Screw 4x4 Truck - JAPEELER
    By japeeler in forum Worklogs
    Last Post: 12-02-2008, 03:45 PM
  5. '04 Ford F150 'puter recommendations
    By 46&2 in forum Car Audio
    Last Post: 02-28-2005, 01:16 AM
Tags for this Thread
