the rr plugin allows for as many as you can connect...
Printable View
ok. and what if you dont know about programming ?? will it be easy to make a programm? i was planing to learn anyway :D also, can you have many devices working together?
i dont know, i can think of milions of usages:D But especially opening and closing the electric windows. But i gues just an inderface with 4 buttons ON/OFF are enough, and max 2-3 devices!!
is it possible to get programing ex. in vb.net. i just ordered 1 of these. i am using visual studio 2012. i need code to turn on relay, read input, and i need to know what baud rate, parity ect.
its not a serial device...
there is a .net dll, you can refernce from your vb.net application
there is also a C# example on how to use
vb.net wont be too much differnet
there are c# to vb.net convertors out therr too
you can put a few lines in: http://www.developerfusion.com/tools.../csharp-to-vb/
i am new to programing but i just made one to controll a usb 8 relay board. i like this idea due to the inputs. is there an example of code you can send to the com port to turn relays on, off, and read input state?
there is sample code on the cd supplied with the product
(source to the test application)
you can also download the cd here: https://dl.dropbox.com/u/36725479/Mi...%20Gadgets.zip
