Results 1 to 10 of 10
Thread: Hardware Review: Series DTA45 Internal Audio Amplifier
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    What is it?
    The DTA45 is a compact, 2 x 25WRMS car audio amplifier designed to fit a Nano ITX enclosure.
    The Verdict:
    The DTA45 Internal Amplifier is a good solution for installers that are looking for a simple, compact solution to connect a car PC to car speakers. Its charm comes in the ease of installation. While its power won’t rattle any neighborhood windows, the DTA45's sound quality is on par with most quality head units. Whether or not it lives up to its “audiophile quality” moniker will solely depend on the users available software tuning option and overall impression of what “audiophile” means.
    The DTA45 is available at the mp3Car store
    What’s in the box?
    The DTA45 comes neatly boxed with 1 power connector, 1 audio-in connector, 1 motherboard audio connector, instructions, and a set of plastic standoffs.
    Description:
    The car PC hobby has always had a defining line between where the computer ends and the car audio equipment begins. When it comes to getting the PC sound out to the car speakers, there were normally two choices; stick with an audio head unit, or go with a larger and more expensive car audio amplifier. Both of these options come with their obvious drawbacks. A head unit takes up precious dash space, and an amplifier’s expense can sometimes exceed the cost of the PC. The DTA45 attempts to blend a car PC and car audio in a manner which won’t break the budget and won’t require a work around for monitor installation.
    Measuring in at only 105 x 63mm open frame, the DTA45 is smaller than most any head unit or amp you can buy. One of the benefits of the reduced size is mounting locations. The DTA45 can fit in the smallest of car PC cases. In fact, you can even connect the DTA45 board directly to a motherboard with a compatible 10-pin audio connector. Having an amp this small eliminates the need to run long wires to the rear of the car and completely eliminates the need for large, noisy composite connectors. Even without the compatible onboard audio connector, you can connect the DTA45 to the 3.5mm jack on the back of the motherboard with a quick splice of a 3.5mm stereo cable.
    With the size of the unit, you can most certainly expect some omissions when compared to most audio amplifiers. You will not find any crossovers, gain, or any controls at all onboard. This means getting the best sound from the device will in most cases require software-based equalization and crossover settings. That being said, the sound without much adjustment is of high quality. The DTA will provide ample high and mid-range, and even provide a small amount of sub frequencies of it its wee 2x25 watts RMS. Truth is, unless you plan on attempting to wake the neighbors, the DTA45 should be enough for motherboard audio. The rest of its specifications indicate it’s at minimum on par with current OEM head units today.
    Another drawback which may ultimately hinder compact installation is the fact that, like most amplifiers, the DTA45 gets hot. In my testing, there was a time after several hours of use the built-in thermal protection shut down the DTA45. Turning on a case fan solved the issue, so it may not be a good idea to install this device in a fan-less case.
    A benefit to most car PC users is the “soft-on” technology which allows the DTA45 to eliminate the dreaded speaker pop when the amp is powered before the PC. In fact, there were no clicks, pops, or any of the other noises that usually plague car PC audio installations.
    The Good:
      ● Small footprint allows for direct installation to motherboard
    ● Offers quality audio at a fraction of the expense of car amplifiers
    ● Built-in speaker “pop” elimination, voltage and temperature cutoffs
    ● Two-wire power connector eliminates the need for two 12v sources
    The Bad:
    ● No onboard controls for gain, crossover, or high/low pass filter
    ● Less power than aftermarket car PC amplifiers
    ● May require a cooling fan depending on installation preference
    The Verdict:
    *This review was done with the following supporting hardware: Intel DG45FC built-in audio, Infinity Kappa 60.9cs component speaker system.
    Jan 2008
    thanks for your review!
    Jan 2008
    i also wanted to add the biggest problem i have with this amp.
    both sites, bybyte, and mp3 car list this amp as a 4ch capable amp. it is not. it is only 2 channels.
    according to the documentation of the amp chipset, it is not a 2ohm capable amp, which means that while you can use 4 speakers, attention to ohms law is required to ensure that you don't blow up the amp..
    edit: huh, i thought this would auto-add to my last post...
    (and just incase anyone is interested-- this is a very similar chipset's pdf documentation)
    Woodbridge, VA
    Blog Entries
    55
    agreed.. I'm not sure if anyone would look at the specs and attempt to split the 2 channels but is not advised.
    Live mp3Car Facebook Chat
    Oct 2011
    hi there. i'm quite new to car pcs and not very handy with electronics. but i can get access to a local audio shop that can help me out with that.
    question about this amplifier: will it fit inside a nano-itx case with all other peripherals installed? i know that's quite an open ended question so let me narrow it down a bit:
    a) motherboard
    b) hard disk
    c) LCD screen
    d) power supply (m3-atx to keep size down)
    e) anything else i missed??
    with all the above inside a nano-itx case, would this amp fit?
    Jan 2008
    check nivanov's build thread-- he took a lot of pics doing what your asking.
    Oct 2011
    ok, i'll take a look. thanks.
    Jun 2007
    Boston MA
    Not only did soundman help me with the build, he's now selflessly promoting it
    Jun 2007
    Boston MA
    Also, I would highly recommend you go with "TDA7850 With Denoiser" kit from ebay:
    It's a 4 channel amp so you don't have to worry about wiring multiple speakers per channel
    It works off unregulated 12V, while DTA45 needs regulated 12V
    It contains onboard ground loop isolators
    It's 25 bucks
    Oct 2011
    thing bout my car is, i have 4 speakers but all 4 are up front. the rears have mounts and holes for speakers but none are installed. the stock headunit does not have a front/rear balance because all 4 speakers are wired as front left/right speakers. therefore, a 2 channel amp is still ok.
    HOWEVER!!!!! i have plans to install rear speakers. and i don't want to mount 2 of these amps if possible. i'm thinking of building everything inside a bybyte blackbox so that i can move the car pc to other cars in the future easily. so having 2 of these amps and having to deal with the heat they produce in a country where it's 36 degrees celcius on average all year round is a big no no.
    i'll definitely be looking at ebay for this solution.
  1. Hardware Review: JL Audio CL-RLC volume controlled preamp
    By soundman98 in forum The Review Palace
    Last Post: 06-12-2011, 09:30 PM
  2. DTA45 Internal Amplifier - current?
    By riv in forum Car Audio
    Last Post: 02-08-2011, 07:05 AM
  3. Suggest an internal amplifier please!
    By nivanov in forum Car Audio
    Last Post: 12-31-2010, 09:45 AM
  4. Hardware Review: 41hz.com Amplifier Kit
    By swift_gti in forum The Review Palace
    Last Post: 04-29-2009, 12:36 PM
  5. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
