Page 14 of 31 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 308
Like Tree1Likes
Thread: Introducing Mimics. The ultimate iPhone-in-your-car experience
  1. #131
    Apr 2009
    I'm just curious what are peoples options that have headunits with the amp built-in, if they change out their headunit with say the lillput mimics double din option how will they get audio into there car wiring harness and what will drive that sound?
    Ofcourse you can buy high end seperate amps etc but i'm jus curious what budget options there are.
  2. #132
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    I use the kenwood Kac 64404 amp. It was only $100 and provides my mimics system with some great sound.
  3. #133
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    oh and just using the crutchfield wiring harness for you vehicle is good enough to wire an amp
  4. #134
    Apr 2009
    Cheers for the reply,
    Just another question,
    When i'm out putting video from my iphone to my lilliput 619gl or 869gl i'm left with two black bars at either side of the screen.
    I'm using the displayout programs from cydia.
    How do you get the video to full screen like on the demostration videos?
  5. #135
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by foster182 View Post
    If you have a look in the DisplayOut options, [Settings>DisplayOut] you can adjust the screen using the sliders in "scale", "aspect adjust","horizontal offset" and "vertical offset".
    I have had a few people ask this exact question. I shall update the user manual to include this.
    Hope this solved your issue.
    Quad-Core JellyBean headunit... WTF!
    MimicsX2 - Whats your flavour ?
  6. #136
    Apr 2009
    Quote Originally Posted by customGadz View Post
    Yes i'm able to change the scale, but when i fit to either side of the screen, it's cutting out the top and bottom of my iphone screen.
    Its the right height i just need to change the width.
  7. #137
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    If you use the Apple HDMI cable as included in the cable option, then it goes full screen. Thats what we used in the demo videos for my car, and what i currently use now. I'm on iOS 4.3 on an iPhone 4
  8. #138
    Apr 2009
    Quote Originally Posted by optikalefx View Post
    My apologies i ment to say i'm using the a/v composite cable, that might be why its showing up like this.
    So if i use a HDMI cable it will solve this problem?
    Thanks.
  9. #139
    FKA CivicModz
    Mar 2011
    Australia
    Thanks.
    If you use HDMI there is not need to tweak DisplayOut, if using A/V composite or VGA you will need to tweak it to fit the screen. Just make sure to re-calibrate after adjusting screen so your touches are accurate again.
  10. #140
    Apr 2009
    Brilliant, thanks for the help guys.
  1. Ultimate In-Car iPhone Screen Duplicating Kit, GPS Tracking App
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 08-14-2010, 11:40 PM
