Page 23 of 31 FirstFirst ... 13141516171819202122232425262728293031 LastLast
Results 221 to 230 of 308
Like Tree1Likes
Thread: Introducing Mimics. The ultimate iPhone-in-your-car experience
  1. #221
    Nov 2005
    Quote Originally Posted by customGadz View Post
    The digital audio is carried via the HDMI cable. We have seen a small in-line box link that can extract the audio and give you optical/RCA output. Just bear in mind that the iphone can't adjust the volume of the audio output from the dock connector. So external volume control or your factory AUX input will be required.
    Yeah, some type of HDMI to Composite converter "box" would be a nice solution that only uses the 30-pin connector. I didn't know about the lack of audio volume control from the dock connector though, which would be problematic for me since I want an iPhone only solution......
    This HDMI to VGA/RCA box here looks interesting though.....
  2. #222
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by jmciver View Post
    Most digital amps have a small separate volume control with equalizer for easy adjustment. Another popular option is using a basic single DIN headunit for the amp/equalizer and using the external screen for the iphone display. This method will be limited on what space you have as you will require a single DIN + a double DIN slot.
    Quad-Core JellyBean headunit... WTF!
    MimicsX2 - Whats your flavour ?
  3. #223
    Nov 2005
    Well how difficult would it be to develop a hardware and/or software solution that can control the digital audio volume from the iPhone or part of Mimics? So the next Mimics iteration could be a "black box" that incorporates the current Mimics board plus the HDMI to VGA/RCA board similar to the converter in the post above (which is not that big or expensive), with some software developed via Cydia to control the digital audio via the iPhone. If the software volume control is not possible due to restrictions from Apple (that Cydia programmers can't bypass), then a manual volume control separate from the iPhone should be possible, right?
  4. #224
    FKA CivicModz
    Mar 2011
    Australia
    The audio output of the iPhone is a line-out signal and is fixed internally via hardware. Integrating HDMI/VGA in the mimics would cost more than the cables that apple makes millions of. So if using the line out of the iPhone an external volume control is the only way.
  5. #225
    Nov 2005
    Yeah, I understand where you are coming from....
    Switching gears a bit, I have a question about video quality. Is there much difference between using the Mimics with a VGA monitor vs a HDMI monitor? I currently have a carpc with a Xenarc VGA touchscreen and would like to use that monitor first before potentially buying a new one. I would think that a VGA vs HDMI picture on a 7" monitor would be difficult to see a difference (compared to VGA or HDMI vs Composite/S-Video, which is a huge difference in video quality). If the picture quality using the iPhone VGA adapter is as good as the picture quality with my current carPC setup, I am good with that.
  6. #226
    FKA CivicModz
    Mar 2011
    Australia
    In terms of pixel-per-pixel it is exactly the same as not many 7" monitors are 1080p. The only difference that we have noticed is that the colors are slightly different. You can't actually tell unless you have two monitors side by side. So quality difference is very minimal.
  7. #227
    Nov 2005
    I have another question for you.....
    Since I will be using a VGA monitor, do you still offer a modified iPhone VGA adapter with charging capability since the VGA adapter made by Apple (and most manufacturers) does not support charging (unlike the Digital A/V adapter, which does)? And if you still offer this service, would you be willing to modify the VGA adapter here which also has audio out via two RCA plugs?
  8. #228
    Jul 2008
    I'm a very happy owner of mimics.
    It worked perfectly until last week when I decided to update the iphone to ios 5.0.1 unthetered.
    My iphone no longer connect to mimics.
    So Don't Upgrade to ios 5.0.1 !!!!!
    I'm waiting for new drivers... or a solution !
  9. #229
    FKA CivicModz
    Mar 2011
    Australia
    Hi, yes we still do modifications of VGA cables to enable charging. You can either send us yours or we can ship one already modified to you.
    Quote Originally Posted by elitno View Post
    We have encountered as issue with some users of the mimics with the untethered iOS5.0.1. We have got it working, but many customers can't get it to work. We are looking into the issue and the fix will just be a update in the "mimics driver" in cydia.
  10. #230
    Jun 2011
    Eastern Oregon
    Ordering Modified VGA Cable
    [QUOTE=customGadz;1465967]Hi, yes we still do modifications of VGA cables to enable charging. You can either send us yours or we can ship one already modified to you.
    How would one go about ordering one of these already modified? I already have an HDMI adapter but it is slightly short for my setup and I dislike having to connect two cables.
  1. Ultimate In-Car iPhone Screen Duplicating Kit, GPS Tracking App
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 08-14-2010, 11:40 PM
