Page 9 of 32 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 319
Like Tree1Likes
Thread: Introducing Mimics. The ultimate iPhone-in-your-car experience
  1. #81
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by Acrturus View Post
    To get around the problem of maybe not always having my iPhone in the car, or if other people drive it, I am curious if I could use an iPhone 3GS or iPod Touch 2ng Gen?
    iPhone3GS is 100% compatible with the mimics, you will need to use the A/V cable for video as it doesn't have VGA/HDMI support. The best non-iPhone solution would be the iPod 4th gen.
    Basically any iOS device that has video out capability and bluetooth will work with the mimics.
    The iPod touch 2nd gen hasn't been tested yet but it should work, don't quote me though
  2. #82
    Jun 2011
    Eastern Oregon
    PC and Bluetooth
    Quote Originally Posted by Jensen2000 View Post
    Right now, there is no way to connect a PC and the Mimics to the monitor at the same time. The Mimics takes over the 4 wire touch screen and uses the signal to broadcast to your iPhone. Future plans may include a 'switch.'
    Can you connect a pc and Mimics at the same time and just use a physical mouse and keyboard for the pc? I understand you need the 4 wire ribbon cable to use the touch screen with Mimics, but does it take over all video inputs? I wouldn't even mind pulling out the dash to switch video cables for use with a pc but I don't want to be switching the ribbon cable back and forth.
    Also, can you connect multiple bluetooth devices simultaneously? I would like to free myself from having to connect two cables to my iphone every time and instead stream my music to my stereo, and maybe even add a mic to get around the echo problem, using bluetooth.
  3. #83
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    You can have both a PC and mimics, you just need to switch the video input over. Instead of using a mouse and keyboard, i would just get a Griffen Powermate (the silve knob thing) to navigate around.
    You can't use any other bluetooth while the mimics bluetooth is on. The iPhone itself does not support this sadly.
  4. #84
    Jun 2011
    Eastern Oregon
    Too bad it can't be jailbroken to allow simultaneous bluetooth devices
  5. #85
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    Yea its a hardware issue, with the bluetooth they put in the iPhones.
  6. #86
    Jun 2011
    Eastern Oregon
    Does the Mimics Frame option come with the backup camera wire exposed, and is there a way to rotate non-landscape apps 180 degrees so they are easier for the driver to read if need be?
  7. #87
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    Quote Originally Posted by oregonhomeboy View Post
    It does have the wire exposed. Currently the apps will be sideways if they dont have a landscape version. You can let sbRotator rotate them that way, but the touch wont be accurate to that rotation.
  8. #88
    Jan 2008
    your not off to a good start with that link to a non-contributing company...
  9. #89
    Apr 2009
    anyone know if this is on sale yet?
    will this work on a Lilliput 869GL-80NP/C/T?
    i've no idea if the 8'' screen uses a 4 pin ribbon cable.
  10. #90
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by foster182 View Post
    According to the specs your monitor is compatible. It is infact a 4-wire touchpanel.
    I do believe mp3car are shipping very shortly.
  1. Ultimate In-Car iPhone Screen Duplicating Kit, GPS Tracking App
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 08-15-2010, 12:40 AM
