Results 1 to 10 of 15
Thread: Car Computer Install: Building the Computer
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    Embed this video
    Sean Clark, from mp3Car, shows us how to build a typical Mini ITX car computer. The Heyco grommet protects the power input wires from chafing. He uses a pneumatic punch to make a hole for the grommet and then feeds the mp3Car Quick Release Kit into place through the Morex 5677 computer case. The installation of the motherboard involves installing the Intel Core 2 Duo processor, cpu fan, memory, and Intel wi-fi card into the PCI Express slot. Once the motherboard is ready, the Min-Box M2-ATX is configured and bolted into place. Once the motherboard is installed into place, installation of the CPU fan, hard drive, and top of the case is done. Extra USB ports are extruded from the motherboard with an mp3Car USB Supersize Kit. During the initial boot, testing the computer involves entering the BIOS screen and verifying the CPU, memory, and processor are detected.
    Jan 2008
    well, i would love to watch it, but i clicked on the volume, it reloaded in a ipod format--which it appears that it will do if i click anywhere within the video player window, and now, i either need to rewatch 5min, or just not watch at all--i cannot click to go to where i left off without the video going to a different page-- and i have been attempting it for the last 30 min... i can't forward the footage, and press the 'stop loading' button fast enough...... your video player aggravates me!!!!!!!!!!!!!!!!!!!
    i really feel sorry for newbs that are trying to learn from this footage-- there is no way to rewatch any part of it....
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Can you send me a small video of what you mean? I'm able to let the video load ahead of me and click anywhere that has buffered. I can skip the middle in about 1 minute.
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    It plays fine in Chrome. Skipping forward (after it buffers enough) and backwards works.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jan 2008
    stupid firefox. i tried it in ie, and it is working fine. i'll need to keep that in mind..
    May 2010
    Australia
    Yeah I tried it in Firefox.. I could do everything but it kept opening a download this video everytime I clicked..
    I thought a few things seemed to be done the hard way.. but maybe it is me that does things the hard way..
    Jan 2008
    ok, time for my comments :
    the ease and simplicity of the press is great, but i wonder if showing you drilling and filing the hole would have been better to prepare people for what they most likely would need to do to get the same effect..
    i know mp3car used to sell it, but i can't find it in the store anymore-- techflex or a similar product, like split loom:
    http://www.parts-express.com/wizards...fg&srchMfg=299
    it would really help keep all those wires outside the case nice and clean.
    newb note: something that you did, but didn't mention--keep the board on a piece of foam, or mount it in the enclosure. not critical, but when it comes time to install the cpu heatsink, without it being mounted to the case or on foam, it can be a little more tricky.
    is there any major advantage to the intel pcie wireless over the one that is included with the zotac board(i believe most use a via chipset)?
    i was waiting for you to drop the screwdriver on the cpu pins the other easy thing to look at to install socket 775 cpus is to line up the 2 notches about 5mm above the bottom edge where that yellow notch is.
    screwing mobo to case-- i like to thread the screws in but leave them loose until all the screws are installed-- sometimes tightening one down mis-aligns the others..
    cpu fan wires-- i like to spin the fan/heatsink assy. while holding the fan wire connector, so the wires twist around each other, so you end up with a 'rope' of wire-- if not, there is always that one rogue wire that likes to stick to the fan blades...
    great job on the video!
    May 2010
    Australia
    Some good comments there ^^^
    Yeah I was highly interested that all the parts were put on the board before it was installed... I always put my board in first so that I don't break the board trying to put bits on..
    The other thing I was going to say was I usually just put the backing plate in then slot the motherboard in.. Not sure if space constraints made you do it the way you did..
    Jan 2008
    i normally do that as well, but i assemble mini-atx boards in full-atx cases, so i have tons more room...
    for a small case like that, it would have been much easier to assemble most of it outside the case. no matter how skinny you are, working on a case that small makes everyone feel like they have fat fingers...
    May 2010
    Australia
    Yeah I know what you mean..
    I put a mini itx system together for a friend in this case:
    http://www.pccasegear.com/index.php?...ducts_id=16855
    I did it all in the same order in the case like I normally would but there were a few bits that took a little bit longer....
  1. Car Computer Install: Building The Computer
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 03-07-2014, 07:46 AM
  2. building in-car computer
    By ls00722 in forum LCD/Display
    Last Post: 07-12-2004, 05:10 AM
  3. Building a computer
    By andrew8485 in forum General Hardware Discussion
    Last Post: 05-31-2003, 03:45 PM
  4. Building ANOTHER computer for MP3Car
    By bdk3clash in forum General Hardware Discussion
    Last Post: 12-15-2000, 10:00 PM
  5. Need help building computer
    Last Post: 12-12-2000, 12:44 PM
