View Poll Results: What method do you use to connect wires?
Voters
6. You may not vote on this poll
  • Crimps
    3 50.00%
  • Solder
    2 33.33%
  • Electrical tape
    1 16.67%
  • wire twists
    0 0%
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Car Computer Install: Installing Peripherals
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    Embed this video
    Sean Clark shows us how to run the various cables for each peripheral. Get creative. Wires can be run in more places than you think. Remember to be careful when you're prying against plastic interior panels and use a cloth to protect them. Zip ties work wonders to attach components behind your dash. Make sure to allow enough space for HVAC vents when zip tying your items in tight spaces. Purchasing a wiring harness for your vehicle eliminates the need to splice factory wiring. One can easily tap into each speaker channel and feed to your aftermarket amplifier with a vehicle specific harness.
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    I couldn't help but notice your use of wire crimps, honestly, especially in a vehicular environment with vibrations, stop and go ect... Solder and heat shrink would have been a more time consuming but wiser choice. Other than that the install is coming out very nicely!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    he... you should see some of my "crimps". Its amazing i'm 7 years strong into the hobby and havent had a single fire. I should probably have stock share in some electrical tape corporation.
    Live mp3Car Facebook Chat
    Oct 2006
    Texas
    Quote Originally Posted by Sonicxtacy02 View Post
    LMAO!! Love the car man, my buddy has an altima, is it yours or are you doing an install for someone else?
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Yea this is my baby. Got her about 8 months ago and couldn't wait to take off the side panels.
    Jan 2008
    the videos seem to be getting shorter?
    some great points on using the sacrificial harness for wire connections, and using the coat hanger-- while doing this, it doesn't hurt to tape the wire to the coat hanger to help keep them together a little better(i fish wires through my car using this method).
    i am not crazy about crimp connectors either, esp for someone new to using them, though as long as they are crimped correctly, they should not have many problems-- i prefer a crimper like this that crimps the connector in a 'U' shape, as those seem to create a better connection then the other versions of crimpers.
    of note: of the cars i have installed sound systems in, i have found that a wire run from a engine bay battery to the truck is usually just around 20ft, so i always order 20ft of power wire. at the very worst, you end up with 2-4ft extra, and if you used pure copper wire, take it in for scrap, and get some of your money back.
    Quote Originally Posted by david69leonard View Post
    that would be a whole 'nother video series to teach people how to do that...
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    I never thought to record the crimping action. But we have heavy duty ratcheting crimpers that allow me to interchange heads for the various crimp sizes.
    Jan 2008
    ^ that would be perfect for people new to crimping, though at about $100-200/ea, are well above the hobbist-cost... the crimper in my post is currently $23.99 on amazon. just be sure to squeeze it all the way closed to complete a crimp(that's where i really like the ratcheting action of the more expensive model-- it won't let you release until the crimp is complete).
    off topic, but what flashlight are you using in the car?
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    One thing a new crimper user can do is use the floor or table against the crimp handle at an angle. That uses the "Natural Force" of the crimp tool closing against the floor, which is much stronger than your hand muscles. (we had to do this even with the rachet for the 8 gauge hot wire)
    Its some camera light we had in the camera box. I highly DONT recommend it. It burnt through stephens pants, and every time it fell we had to scramble to pick it up because it would have very quickly caught the seat on fire.
    Mar 2011
    Marietta, Ohio
    I can think of a couple things but it is really nitpicking, I guess. The coat hanger method is always a good tool. However, and I know you said you could see the hole you wanted to go through, but sometimes it would be best to remove the panel. This way you are not blindly poking around esp. under the dash.
    Solder and heat shrink FTW. I can't see recommending just twisting and taping wires with electrical tape. Too many possibilities of coming undone and who wants to do this several times? Those intermittent grounds, etc. can be hard to diagnose. Crimping should be okay with a good crimper.
    In my build I have found it is best to use the after market harness for speaker wiring to 4 channel amp as you mentioned. It's also a good source for your ignition on/off wiring trigger.
    Other than that very informative and look forward to your next video.
  1. Installing a computer in a 2010 WRX
    By parthew in forum Newbie
    Last Post: 11-09-2010, 11:18 PM
  2. Installing help Infill T3 Computer
    By riggscm in forum General Hardware Discussion
    Last Post: 10-27-2008, 08:04 AM
  3. Replies: 34
    Last Post: 05-27-2008, 09:19 AM
  4. Installing computer in-dash?
    By SuperMatty in forum General Hardware Discussion
    Last Post: 06-04-2003, 04:21 PM
  5. Thinking of Installing a computer. Need Help!
    By Sike in forum Software & Software Development
    Last Post: 06-03-2001, 08:06 AM
