Results 1 to 10 of 18
Thread: Hardware Review: Rupel iVox102h HD SSD Driving Recorder
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    What is it?
    The Rupel iVox is a high-definition audio/video recording device with built-in GPS, accelerometer, and rear camera support. Video is recorded for playback on an included 16GB USB solid-state drive.
    The Verdict:
    The Rupel iVox102h is a feature rich recording device with all the bells and whistles. It’s “install and forget” configuration as well as its high quality image capturing means the iVox102H is a very versatile device. It seems its creator has done an amazing job of incorporating a variety of sensor capabilities into a useful and intuitive device.
    READMORE
    What’s in the box?
    The iVox102H comes with the high-definition camera, a 16GB solid state USB drive, a windshield mount with GPS built in, a 6 meter cigarette lighter power plug, and a rear auxiliary camera. Wire looms are also generously thrown in.
    Description:
    In car, I talk, a lot. A lot of the things I say cannot be repeated in this blog post. In fact, I should probably invest in installing a swear jar somewhere in my mass of PC components and wiring. The Rupel iVox102H was the device that taught me this. That’s because this high quality audio/video capture device sees and hears all that’s going on during my daily commute. It does a clever job of recording what I see as a driver on the busy streets of the DC metropolitan area, all while (optionally) recording all audio that echoes throughout my travels.
    Installation for the device is only slightly more difficult than installing a portable GPS unit. The included base, which features a built-in GPS receiver, simply sticks to your front windshield or dashboard. It connects to the camera with a standard VESA mount and 3.5mm cable so that the GPS data can be written to the camera’s 16GB solid state hard drive, or optionally, a SD card. Next step in installation is to simply run the power line to your nearest 12volt cigarette lighter port. Then optionally the camera will take a 3.5mm audio/video out and yet another 3.5mm jack for the included auxiliary rear camera.
    Once installed, the iVox102H powers on when power is supplied through the cigarette lighter port upon ignition, and powers down shortly after the vehicle is turned off. Optionally, you can connect the device to an always-on 12volt source and record 24/7, though, as always applies in the car, this will only work if you maintain 12volts or more at the battery.
    Shortly after powering on, the camera will automatically begin recording, emitting a simple “recording started” phrase which is elegantly created. This is the “normal” mode for recording. A secondary “event” recording mode is automatically created based on the built-in accelerometer crossing a preset threshold. In this automatic mode, the iVox102H will recapture the prior 15 seconds before the event, and continue recording the preceding 5 minutes after the event before returning to normal mode again. The idea behind event mode is that the moments that need to be captured are captured without the default 30 second splitting the camera saves the files at during the default setting.
    While the iVox is declared as an “HD” capable device, the reality is at its highest setting the primary camera records at 3-megapixels. The video quality is still good enough to capture a license place or an occasional street sign. The rear camera is of lesser quality, but is good enough to use in parking scenarios, which is what the creators designed it for.
    The iVox102h comes with a Rupel Viewer application which allows the video files created by the capture device to be displayed with metadata in tow. The app will show you your calculated speed, latitude, longitude, and built-in accelerometer values in a nice graphical interface. You’re also presented a Google map window which will show your recorded travels. The application, while useful for configuring the camera for things like quality, time format, and distance display, requires a very large resolution display (no car PC will display it), and doesn’t genuinely do anything special. All metadata is shown embedded on the video replay, so users are welcome to simply use they’re own video application.
    The Positive:
    • High quality video capture without the need for a PC
    • Composite video output means you can connect the device to a PC if you wish
    • Quality imaging and audio pickup
    • Auto-power on/off
    • Captures GPS and accelerometer data and uses it for event detection
    • Included software gives you all the video information in a nice GUI
    • Two channels means you can record from two cameras
    The Negative:
    • Camera itself is somewhat large for windshield mounting
    • Can run into cable management problems if connecting all accessories
    • Included application requires a high resolution display to use.
    The Verdict:
    [/READMORE]
    Last edited by Enforcer; 12-05-2011 at 06:33 PM. Reason: Copeid and paste full review from soundmans post
    Jan 2008
    you really gotta stop that 'readmore' stuff-- or get optical to fix it..
    Last edited by Enforcer; 12-05-2011 at 06:33 PM. Reason: Move full review to first post
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Woodbridge, VA
    Blog Entries
    41
    Oops forgot to remove the readmore's from the forum post. Thanks E, and as mentioned on facebook, there is no current pricing on this model. Only at the point of gauging interest
    Live mp3Car Facebook Chat
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Excellent review! I sent an email to the company that makes and distributes this unit, sample prices for the 101h with only 1 camera is 220.00us and the 102h with front and rear camera 240.00us. MOQ is 100pc If you need the contact just ask! SNO
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    The 3.5 mm GPS cable is a data cable and not audio, right? I ask because 3.5 is usually associated with audio.
    Also, could you take some more pictures of every angle of the device? I would like to see the operator buttons/interface if possible so I can know what to expect.
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by stonestatue View Post
    yes the 3.5mm lines are just data lines. Audio is captured through the microphone built into the device.
    I can take more pictures but there's only one button, where the led is, that seems to put the camera in "event" mode manually. It doesn't appear to do anything else and the reference material doesnt say anything about it.
    Woodbridge, VA
    Blog Entries
    41
    more pictures of the unit while installed....
  1. Replies: 5
    Last Post: 02-22-2011, 03:41 PM
  2. Replies: 0
    Last Post: 03-18-2010, 06:35 PM
  3. Replies: 14
    Last Post: 04-13-2007, 01:23 PM
  4. Hardware Review: Car2PC Alpine MBUS review
    By MatrixPC in forum The Review Palace
    Last Post: 06-02-2006, 06:39 AM
