Results 1 to 7 of 7
Thread: Hardware Review: Element 7" Touchscreen Display
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    What is it?
    The Element is a 7" Touchscreen display which features HDMI, DVI, VGA & composite video connections.
    The Verdict:
    The Element 7" display is a well-received competitor into the small touchscreen genre. In its first revision, it seems to incorporate most of the criteria which makes a touchscreen device usable in the car. Those looking for a budget display device with great quality and community recommendation should look at the Element as their device of choice.
    What’s in the box?
    The Element comes with the 7" Touchscreen monitor, power supply, a remote control, and a 3.5mm to composite video connector. HDMI is not included, however because the Element uses a separate mini-USB connection for the touchscreen, any HDMI cable will do.
    Please note at the time the photos were taken the Element monitor came only in open frame form. A case is now available for the device.
    Description:
    Every once in a while, sites like ebay turn up a gem for the small market Car PC world. Such is the case with the new Element 7" touchscreen monitor, a device that community member RipplingHurst found while sifting through the items available on that website. His intrigue, which lead to this massive thread of information regarding the device, inspired me to contact the displays creator to review the device's uses for Car PC.
    With that massive thread in mind, lets summarize some of facts regarding the Element display. It is a 7" Samsung monitor with LED backlighting, overlayed by a resistive 4-wire "sunlight readable" touchscreen input device. Note that it is not transflective, but it does a fairly decent job in high sunlight conditions. I would put the device right on par with the high brightness Lilliput displays of recent years in terms of the amount of screen visible when the sun is bearing down.
    The controller for the device supports the famed 800x480 resolution from any video device which supports it. This means sticklers car PC pixel perfection can use their compatible video cards with the Element without the hassle of custom resolutions or firmware hacks. Oddly enough, the device supports many different resolutions all the way up to 1920x1080, far higher than most Lilliput and Xenarcs dare go. Now, most people wont ever use a 7" monitor at that high a resolution, but the ability to do so is worth a bragging right or two.
    Another built-in feature that was kindly considered is the ability to auto switch to composite AV1 on signaling. This request has become more popular with the installation of rear cameras in car PC setups. Auto-on/Auto-off and input resume are all there as well. The creator as definitely done their research in regard to what car PC hobbyist are looking for from their touchscreens. They've even done away with the dreaded "blue screen of boot" no signal screen. Instead of retina burning bright blue, the screen is a subtle black.
    The display quality of the Element display is darn nice at factory settings. Colors are rich and deep, and there's not any noticeable "pixel effect" or ghosting at low resolutions, no matter what input you choose to use. The only poor aspect of the viewing quality was the off-axis viewing angles. Colors quickly turn dark when viewing at modest angles. Unfortunately this is a trait of near all resistive touchscreen monitors, and the Element makes no strides in this regard.
    Installing the open-frame Element in to your car shouldn't be any more difficult than normal. The device will fit into mp3Car's double-din kits available, albeit with some minor controller mounting and cable interference issues. The display fits nicely into the opening of the bezel, with only a minor smidgen of touchscreen white-space showing through. The developer for the device kindly included a long strand of cables connecting the controller board to the button panel, meaning the buttons can be neatly tucked away, or the IR sensor for the remote can be mounted away from the dash panel.
    A minor matter of contention I have with the Element is of personal opinion. The device uses separate USB and HDMI cables, meaning there is one additional wire required to tuck into the dash and extend out to the PC. The benefit to this is the ability to use any HDMI cable, instead of the stiff and often difficult to replace HDMI-to-HDMI/USB cables found with Lilliput and Xenarc monitors.
    The Positive:
    • Above average sunlight readability
    • High quality display with extremely rich color and contrast
    • Includes features car PC installers demand
    • High selection of available resolutions
    • True native 800x480 support
    • Buttons can be easily mounted elsewhere for space saving in installation
    The Negative:
    • Requires a mini-USB wire for touchscreen
    • Uses proprietary touchscreen drivers
    • Height of controller and angle of connectors mean some hacking required for double-DIN kits
    • Poor off-axis viewing angles
    The Verdict:
    Jan 2012
    Does this screen work with mimics iphone module? Please advise! thanks!!!
    FKA CivicModz
    Mar 2011
    Australia
    Quote Originally Posted by hasun100 View Post
    Hi, Yes this monitor is compatible. Just specify you want to use this monitor in your order and will send you the correct touchscreen adapter.
    In future you can ask any further questions at the official mimics thread HERE.
    Quad-Core JellyBean headunit... WTF!
    MimicsX2 - Whats your flavour ?
    Newbie bebopblues's Avatar
    May 2009
    Good review, but you didn't mention where to buy it or how much it cost.
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by bebopblues View Post
    Ebay Link
    Live mp3Car Facebook Chat
    Jan 2004
    Chicago, Illinois USA
    Quote Originally Posted by Sonicxtacy02 View Post
    For those having trouble with the link: the ebay auction # is 110659973152
    Here is the shortened link so it works in this thread: http://goo.gl/DvgaV
    2000 Audio A4 Avant
    CARPC --- 95% Complete / -50% WAF (wife acceptance factor)
    • Intel D525
    • Xonar DS
    • Mo-Co-So Case
    • Xenarc 706TSA
    • Directed HDRadio
    • RideRunner w/ Modified Reborn Skin
    • Winamp
    • ASIO 2.1
    • Console
    • Windows 7
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    what is the touchscreen controller/driver? Can the controller board be laid flat? How long is the cable that connects the controller to lcd?
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  1. Hardware Review: Mini Touch 700 7" Touchscreen Monitor
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 04-25-2011, 03:44 PM
  2. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 08:02 AM
  3. Hardware Review: CarTFT.com TFT Display Suction holder
    By ccsnet in forum The Review Palace
    Last Post: 08-31-2007, 02:12 PM
  4. Replies: 9
    Last Post: 06-19-2007, 08:33 AM
  5. Replies: 14
    Last Post: 04-13-2007, 01:23 PM
