Results 1 to 6 of 6
Thread: Hardware Review: Pittasoft BlackVue DR400G-HD Driving Recording Device
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    What is it?
    The BlackVue DR400G-HD is a high-definition audio/video recording device with built-in GPS & accelerometer. Video is recorded for playback on an included 16GB micro SD flash drive.
    The Verdict:
    The BlackVue DR400G-HD improves over competing video recording devices I've tested with a brighter more vibrant capture and a smaller footprint.
    What’s in the box?
    The DR400G-HD comes with the high-definition camera, a 16GB micro SD card with adapter and USB dongle, a windshield mount with adhesive, a 12 meter cigarette lighter power plug, 3.5mm to composite audio/video cable, and a 3.5mm to composite video cable. Wire looms and instruction/installation manuals are also generously thrown in.
    Description:
    A few months back I did a review on the Rupel iVox102H driving recorder system. One of the negative points for the device was the size. The iVox102H stood out like a sore thumb though no matter where it was placed on the front windshield. Enter the BlackVue DR400G-HD. Similar in technical specifications, the DR400G-HD is a sleek and visually appealing driving capture device, sitting at a fraction of the overall length and size of the competitor. The DR400G-HD definitely improves on the competitors footprint, but can it stand toe to toe in regard to the one area that matters most, video quality?
    Simply put, the answer is a resounding "yes". In fact, in similar conditions, the DR400G-HD replayed my driving sessions with more color intensity and brightness. The technical specifications on the box indicate the camera sports only a 2mp chip, but it appears that despite the size and weight difference between these two units, the DR400G-HD sacrifices nothing on video quality. The size of the unit has no effect on the angle of view either, giving a nice full windshield view. The size savings comes from the lack of a proprietary solid-state hard drive for the BlackVue. Instead, the DR400G-HD utilizes your every day micro SD card, found in most modern smart phones and handheld electronic devices. Simply install the side card into the slot on the DR400G-HD camera housing, provide 12v power, and the device records away. A small hitch in the ease of installation is the difficulty sliding the tiny micro SD card into the camera for people with left-hand drive vehicles. The card slot is on the right hand side of the unit when it faces outward towards the windshield, and if the camera is mounted in the ideal position (behind the rear-view mirror) it becomes quite the chore to insert/remove the card. Most users may opt to simply uninstall the camera from the included mount instead, which can be easily done with a simple press of the lock button.
    Another knock on the competing iVox102H was the bright light emitting from the device when powered. Sadly, the DR400G-HD triples the number of lights, and even causes the record indicator to blink continuously while powered. Thankfully, these lights can be switched off in the settings menu in the cameras playback program. On top of the visual feedback with the lights, the DR400G-HD also utilizes voice prompts indicating when the device is powered and recording is started. These too can be turned off via the settings menu.
    In speaking of the program, I must state, like the iVox, the BlackVue camera stores its companion playback application on the storage medium. That means the playback application can be run from "any" computer. A somewhat disappointing omission in regard to this application is it can not be run on a 64-bit windows system. Hopefully the software team is working on a fix for this.
    Once running the software application does a great job of allowing users to playback video with accompanying GPS mapping and accelerometer feedback all indicated. Users can select different dates and times to watch, and all files can easily be backed up to a larger external storage medium. This is somewhat important because in my week with the device I've filled up the 16GB card several times over with the video at its highest quality setting.
    The audio capture is a bit muddy, especially when music playing in the background, but its still easy to pick up the conversation of people in the front and rear of the car.
    The Positive:
    • Superior video capture quality
    • Sleek and small means it doesn't stick out on your windshield
    • Auto-power on/off
    • Captures GPS and accelerometer data and uses it for event detection
    • Included software gives you all the video information in a nice GUI
    • Parking mode set automatically by accelerometer feedback
    The Negative:
    • Muddy audio capture
    • Software is not 64-bit ready
    • SD card installation is somewhat a chore based on location of slot on the camera
    The Verdict:
    Dec 2007
    There was one person over on RadarDetectorForum.org who drilled just above where the microphone is on the inside. He said it greatly improved the sound quality and planning on making the hole larger to see if that improves the sound even further.
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by protias View Post
    That may be a good plan! I'll try it
    Live mp3Car Facebook Chat
    Dec 2007
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    No video? Who does a review of a video capturing device and doesn't post video from the device? I guess what I'm saying is I would like to see some footage!
    Tidder
    Try RevFE
    Dec 2007
    Video is pretty good, but the audio does suck, even after the mod. I'm in the process of looking for a mobile camera that records to a hard drive, records 1080p, and streams wifi and 3G.
  1. Hardware Review: MJS Gadgets USB IO-1 Relay/Input Device
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 02-10-2013, 01:32 PM
  2. Hardware Review: Rupel iVox102h HD SSD Driving Recorder
    Last Post: 10-10-2012, 02:35 PM
  3. XM AND FM, how to switch recording device
    By Vinister in forum Software & Software Development
    Last Post: 05-06-2005, 03:24 PM
  4. Video camera for recording driving
    By MBL MIKE in forum Input Devices
    Last Post: 04-26-2004, 12:27 AM
