Results 1 to 10 of 19
Thread: Car Computer Install: Noise In The System
    mp3Car Staff
    Jensen2000's Avatar
    Feb 2009
    Seattle, Washington, USA
    Blog Entries
    79
    Embed this video
    Sean discusses problems with noise in the system and ways to eliminate them.
    Jan 2008
    just remember that ground loop isolators and direct-to-battery grounding are not always the only options. you can also try grounding to different points in the car, or, if everything is grounded to multiple points, connect everything to a single point. or connect a length of wire from the outer portion of the rca cable to the ground cable.
    unwanted noise in a sound system is usually the result of what is called a difference in ground potential-- which basically means that some devices have a easier path back to the battery then other devices. the entire idea is to get everything onto the same ground potential, which usually will correct the issue.
    there are tons of different solutions to ground loops and unwanted noise, so if you happen to have a particularly annoying one, i suggest searching sites like realmofexcursion.com, or diymobileaudio.com, or the12volt.com. all those sites specifically cater to car audio systems, and will have tons of info on ground loops and the previous solutions that people have used to correct them.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jul 2011
    Or simply do it by standards like AES48. That should guarantee no noise not only from ground loops but from external interferences (neon lights, RFI, etc..) as well. Long story short... balanced lines with shield grounded to chassis at both ends of twisted pair cables.
    Jan 2012
    Did you try doing the big 3 upgrade? Maybe your chassis was not grounded properly to the battery?
    Sep 2011
    Canada
    hey guys,
    i couldnt contain myself on this post i really couldn't..this is a nissan altima. not some S**tty demestic pile. the grounds in the car are fine, slappy didnt ground it to the chassis like said,
    he used a factory bolt >i.e. seat belt or spare tire nut. 101 of grounding in a car. dont uses factory anything. i will even scan the beginners guide from the MECP book about this..
    second .the paint was not scraped down to metal.(from what was shown)
    and then ground loop iso's!!!! really? come on.
    this really twist my nipples
    only because, how can someone who doesnt know much about cars, teach other people how to do things in there cars.
    this is the blind leading the blind man.
    you sir are the reason people have a bad taste in there mouth about real installers.
    I am sorry for the rant! but come on ...
    Jan 2008
    Quote Originally Posted by Zerohour2100 View Post
    reality check-- nearly all mass produced vehicles in the last 20 years, regardless of the make, are spot welded. and spot welds are not always consistent in their mating of the two panels. this is the issue at hand. i don't care if it's a vw, mercedes, mitsubishi or chevy, they all do that the same way, so that argument lacks substance.
    99% if the time, all the extra stuff like sanding the paint off, and using a non-factory ground point is not needed. i know of plenty of trouble-free sound system installs that used a factory bolt, and never sanded anything. but once you have a issue with a ground loop, these are some of the first things to check.
    4 years ago, i knew how to click a mouse, and open my email. now i use a carpc every day, and have modded my car electrically in ways i barely imagined 4 years ago.
    everything is a learning process. i think sean knows more then he shows in this series..(remember, this is part of a introduction to carpc series, not a advanced tech doument)
    and you leave a bad taste in my mouth. he never claims to be a real installer, that he knows all of it, or has all the answers. and any intelligent person will do the same. it is impossible to know it all. this forum is based on a hobby-ist activity, and as such, some of the installs are crude, or not up to what a 'pro' shop would do. the video series is meant to be a starting guide to new members on what it takes to install a carpc. if you don't like the series, you should make your own 'correct' version. i think they did a great job covering all the different aspects of the build, and showing the different ways of doing things. is it the way i do things? no. but i don't want to make a video.
    HID retro--100%
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Quote Originally Posted by protias View Post
    DELETED BY MOD
    Comments like that are not appreciated on this board...
    RevFE
    My Shop
    Mar 2006
    Colorado, but Canadian!
    This thread has been cleansed. Please keep the discussion to the topic at hand.
    If you would like to debate domestic vs. imported vehicle design and quality, feel free to do so in the Off Topic section found here: http://www.mp3car.com/off-topic/
    1.9in x 2.9in -- 47mm x 73mm
    May 2012
    Humble,TX
    Good example of troubleshooting. Sometimes things just don't go the way you plan them and you have to recover with some intelligent afterthought.
    Mar 2012
    Wanted to see if someone could tell me why it would it would a be a bad idea to run a ground wire from the battery to the trunk (like the video showed.)
    You don't hear about doing that often. I heard it a few times but not as often as I thought you should.
    Granted I am a noob to car audio installs (the right way) LOL. As a noob it makes common sense to me to run a seperate ground to eliminate all the grounding problems that can come up. I have not done it but always thought about doing it that way.
    Besides overkill, not necessary if done right etc. Is there any other major concern for running a seperate ground?
    I know there is also a possibility that a new ground loop can come up or still be there but it seems like 99% of the time it should fix it.
    Any ideas?
  1. Replies: 1
    Last Post: 02-05-2011, 08:20 PM
  2. JL Audio System Noise --- Help!!!
    By saounyang in forum Car Audio
    Last Post: 04-01-2008, 12:59 AM
  3. Argh! Noise in my system.
    By Guy Foster in forum General Hardware Discussion
    Last Post: 04-25-2002, 02:16 PM
