Results 1 to 5 of 5
Thread: Hardware Review: MIMO 720F USB Touchscreen Monitor
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    What is it?
    The MIMO 720F is a USB powered touchscreen monitor with a built-in fixture style mount.
    The Verdict:
    The second iteration of the MIMO 720F touchscreen monitor features improved performance all around. The colors are brighter, touch layer seems clearer, and drivers are more stable. Whether the 720F is the best for you simply depends on your mounting preference, as the mount design can make or break your install.
    What’s in the box?
    The MIMO 720F box comes with the touchscreen monitor, single power/control USB cable, driver CD, mounting screws, and instruction manual.
    Description:
    Ever since the USB Touchscreen Showdown I have received request for a more in-depth look at the MIMO 720F USB Touchscreen monitor. Having had a second go-round with the display, I can confirm basically all of the pluses and minuses from 2011. The 720F is a fantastic option if considering to add an additional monitor your car PC setup... provided you engineer a manner to mount it.
    Easily, the most differentiating item on the 720F is the "flex" mount. Where most 7-inch screens are going to come with a removable bottom mount solution, this version of the 720 system comes with four non-removable mounting arms. MIMO suggests that there are thousands of applications in which to use this unique design, and honestly, I can see many methods in which the mount would be preferred around the house or at work. The available suction cup mount means you can practically mount the 720F on any stationary mounting surface. There's also a headrest mount for display on the go. However, if you're the type who plans an installation that looks like it's meant the be there, the flex mount will more than likely be a hindrance.
    So while prospective purchasers may have a decision to make regarding the 720F's backside, no one will have a problem with the business end. The MIMO device is easily the nicest looking USB touchscreen to date. The bezel is sleek and clean with no forward facing buttons to speak of. Aside from the MIMO logo on the bottom of the bezel, the 720F can absolutely look OEM properly implemented in a car. Even the power light seems to be considered, as it is offset and not blindingly bright at night.
    The good looks continue when your operating system loads and the display comes to life. Where the first generation was inhibited with some pixilation and color banding issues, "Season 2" of the 720F has drastically improved visuals whether during movement or stationary. I'm not entirely positive if it's the improved DisplayLink drivers or the hardware itself, but rest assured the 720F will display the way you desire. Keep in mind though that you're still limited to a fixed resolution of 800x480, and USB display means your operating system must load before the 720F will work.
    As with all USB touchscreens, the driver requirement put Windows users first in terms of display and touch screen support. The included DisplayLink drivers for Windows have been improved and the result is an increase in stability. I have not experienced the problems resuming from suspend modes as I had in previous iterations. Mac OSX users have been added to the list of users that can take advantage of the MIMO display, provided they don't mind having to purchase a third-party USB driver. Android users may not be left out for long, as there are efforts to bring a Android-friendly driver to the front as well for host-mode compatible devices.
    The Positive:
    • Superb display quality which rivals HDMI competitors
    • Uses a single USB
    • OSX and Android driver options are now available in limited capacity
    • Sleek bezel design
    The Negative:
    • Mounting system may limit install capabilities
    • Still requires Windows to load before it will display
    • Single USB cable may cause problems with some USB hubs
    The Verdict:
    The MIMO 720F is available on Amazon
    For a video comparing the 720F with the other latest USB Touchscreens click here
    Mar 2011
    Bay Area, CA
    Will this monitor be able to display movies? Can you test with movies and flash video?
    Jan 2008
    yes, they will smoothly play any video you can feed them. i've got a 7" and a 15.6" usb screen, and both work excellent for that.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Mar 2011
    Bay Area, CA
    Thanks, one last question. Will it play video using this as a secondary screen in Centrafuse?? Last I heard, it could not due to no support for DirectX or hardware acceleration. Do they now support it?
    Woodbridge, VA
    Blog Entries
    43
    Will work with the latest CF just fine.
    Sent from my SCH-I535 using Tapatalk 2
    Live mp3Car Facebook Chat
  1. Hardware Review: Xenarc 700TSU USB Powered Touchscreen Monitor
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 02-15-2012, 10:18 AM
  2. Hardware Review: Mini Touch 700 7" Touchscreen Monitor
    Last Post: 04-25-2011, 03:44 PM
  3. Replies: 9
    Last Post: 06-19-2007, 08:33 AM
  4. Replies: 14
    Last Post: 04-13-2007, 01:23 PM
