What is it?
The Andrea Electronics WNC-1500 is a Wireless Computing Headset featuring digital audio enhancement and noise cancellation.
The Verdict:
The WNC-1500 is an excellent option when looking for a wireless communication device for VOIP. Communication was crystal clear in a variety of busy environments. The headset is very comfortable and provides a secure fit allowing for a pleasant listening experience.
What’s in the box?
The WNC-1500 Comes with the headset, a 2.4ghz USB adapter, USB charging cable, a convenient carrying case, and an instruction manual. Software is also available for download from AndreaElectronics.com
Description:
Andrea Electronics is widely known in this community for the stellar series of Superbeam USB microphones. When installing a automotive PC, the Superbeam was the best available option for hands-free audio communication for a very long time. The quality of the Superbeam bundle has been reassembled into a wireless audio headset named the WNC-1500.
Each part of the WNC-1500 package has been considered for fit and finish. The headset itself is extremely comfortable, which each part of the headset which touches your ear cushioned more than adequately with genuine leather. The attached microphone with included pop filter rests away from the face but in ideal position for vocal clarity. Microphone placement was considered not only for clarity, but it stays out of the way during video conferencing for the most part. The headband is also cushioned and does an excellent job of securing the headset speakers comfortably. Being wireless, the device is made to be mobile, and consideration was certainly made to keep the headset snug without being painful.
The WNC-1500 comes with a convenient set of controls on the right earbud. Included buttons are for volume control, music playback next/previous track, power, and configuration. The buttons are raised with a firm press, but unless you use the headset often, you may find using conventional computer controls more friendly. I find myself hunting for the proper control through trial and error too often.
The most endearing feature of the WNC-1500 set is the audio quality. Its crystal clear that in it's out of the box form, the headset is made for verbal communication. Despite being wireless, I could effectively speak and listen as if using a landline form of communication. There was simply no static or filtering noises with callers, and they never reported issue in response to my end. Andrea calls it "military grade acoustic noise cancelling technology", I'll just say it does the job and then some. The headset does just enough to filter ambient noises locally as to not disturb what your ears are hearing through the 40mm speaker drivers. By default, the headset doesn't thrill in regard to music or gaming enjoyment, but the included software has a 10 band graphic equalizer to aid in this regard. Despite this, I still felt at times that the headset muffled the audio experience while gaming at its most ideal setting. The virtual surround sound feature was lacking.
The WNC-1500 is powered by a built in lithium-ion battery. Simply plug in the WNC-1500 with the included USB cable and it will charge fully and relatively short time. The LED indicator on the headset will indicate when charging has completed. During testing, I observed battery life in the 5-7 hour range, more than enough for one sitting. The wireless range too was outstanding as audio clarity would hardly be affected until I was some 40 feet from the USB adapter. This far exceeds any bluetooth headset I've used to date.
The Positive:
• Terrific audio quality and noise cancellation
• USB rechargeable
• Comfortable design and secure
• Fold away design and included carrying case means the headset will go where you do
• Excellent battery life and range
The Negative:
• Not immersive sound for gamers
• Must use device manager to enable/disable the USB adapter as your primary sound card
The Verdict:
