Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: Automotive Computing (R)Evolution - The Android Head Unit Build - Road Test!
  1. #11
    Aug 2012
    @Sonicxtacy02
    Any news of the image yet?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mikecwel View Post
    @Sonicxtacy02
    Working on it. The touchscreen fix didn't work for me, but i'm working with the people to try to get it solved before building the image. Hope to have it tonight.
    FYI the "help" thread is here
    Live mp3Car Facebook Chat
  3. #13
    Constant Bitrate Lankin's Avatar
    Jun 2009
    SPORTS JUNKIES ON 106.7 THE FAN? They are the main reason I had to keep FM radio in my build haha. Any plans on adding true FM or are you content with streaming it via tunein?
  4. #14
    Jul 2013
    Quote Originally Posted by Sonicxtacy02 View Post
    As with most test scenarios however, I do have a couple of complaints with the install as it stands. The Anker external battery pack is not living up to my expectations. It appears the battery life is heavily effected by the ambient temperatures. Inside, the battery lasts for several days under a charge with no power usage mitigation. In the summer heat inside the vehicle, the battery barely manages to last 10 hours. Also, at 1.5A input maximum, it takes close to a full day to charge the battery, meaning my car will never truly charge the battery properly. The Anker portion of the project will be scraped for now.
    I'm surprised to hear that the heat affected the life of the battery back so dramatically. I believe Lithium Ion batteries, such as those used by your battery pack, can be affected by heat in this way. I suppose it is good that you are conducting the trial during the summer so you realized the problem quickly.
    The lead-acid type of your Kinetik HC600 battery surely is not affected by heat as a lithium ion battery would be. I like the idea of the ODRIOD being "always on". I wonder if the draw is low enough that it could simply be powered by the vehicle's factory battery even when the car is off? If not a second small lead-acid style battery wouldn't be too bad.
  5. #15
    Philly
    Funny I haven't come around the forum in years... and I'm actually building a car pc with my Odroid-U2 hahaha Great work...
  6. #16
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Lankin View Post
    Haha yes, that's basically the only radio station I listen to locally! Initially I wanted to get the HD Radio hooked up, but honestly.. tunein gets me a LOT more stations and I don't have to worry about static, a problem I've always had in my RSX due to the crappy powered antenna. I've been monitoring my data usage and I'm not even scratching the surface of my 10GB plan, it makes sense to just keep on streaming.
    As a testament to the ODROID install, I officially started yanking Windows PC hardware out of the car. Between USB extensions, audio cable extensions, and power wiring, I pulled out about a good mile of cabling from the car lol. As for hardware I've removed, there's the HD Radio, XM radio (replaced via the streaming app as well), TPMS (which I plan to reinstall once I replace my worn out sensors), Thumb keyboard (Android OSK and voice command makes it obsolete), Apple Bluetooth Keyboard (ditto), and the Andrea microphone adapter. The actual Windows computer is still installed, but it's going to get snatched out soon. I just cant see myself going back to using a Windows based PC. For all of the hurdles that have been overcome over the years, its still far too inefficient and unstable when comparing to the ODROID install.
  7. #17
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by JamesE View Post
    I honestly wouldn't depend on ANY factory battery to leave a 5v device always on. Even if the device were the survive between charges the damage done to the battery over time would add up to the point to leave you stranded. Last night was the first night I had the ODROID continuously powered by the auxiliary battery overnight, and while it survived, the voltage on the HC600 went from low 10v to low 7v. Obviously this battery needs to be replaced, but it was still enough to keep the X2, Mifi, and USB Hub going.
  8. #18
    Aug 2012
    Hi,
    @Sonicxtacy02
    Have you managed to zip the image?
    If it possible, could you zip your own because it seams to be working on your videos?
    I could test it that way.
    As I can see it would be enough for my build
    don't bother with your apps, I will be using different ones.
    By the way, why don't you use a 220 to 12V adapter?
    Thank you (I know I'm asking very much)
  9. #19
    May 2011
    If you have intergrated GPS in the device, you can use the GPS signal to grab the time. But that would be in the NMEA protocol...
  10. #20
    Aug 2012
    Hello to all
    I tried once again to build this kernel but I have an error near the end.
    When I try to copy the modules to Odroid I get the error
    find: "./.cache/dconf": permission denied
    find: "./.config/enchant": permission denied
    Any help?
    Thank you
    EDIT
    I tried once again and it apears that there are errors in the lines that I added
    moi@moi-ET2400IN-1G:~/kernel_4412$ make -j4 ARCH=arm zImage modules
    scripts/kconfig/conf --silentoldconfig Kconfig
    CHK include/linux/version.h
    CHK include/generated/utsrelease.h
    make[1]: `include/generated/mach-types.h' is up to date.
    CALL scripts/checksyscalls.sh
    CHK include/generated/compile.h
    GZIP kernel/config_data.gz
    IKCFG kernel/config_data.h
    CC kernel/configs.o
    LD kernel/built-in.o
    CC drivers/hid/hid-input.o
    drivers/hid/hid-input.c: In function 'hidinput_hid_event':
    drivers/hid/hid-input.c:826: error: 'direction' undeclared (first use in this function)
    drivers/hid/hid-input.c:826: error: (Each undeclared identifier is reported only once
    drivers/hid/hid-input.c:826: error: for each function it appears in.)
    drivers/hid/hid-input.c:827: error: expected ';' before 'if'
    drivers/hid/hid-input.c:836: error: invalid suffix "x" on integer constant
    drivers/hid/hid-input.c:836: error: stray '\' in program
    drivers/hid/hid-input.c:836: warning: missing terminating " character
    drivers/hid/hid-input.c:836: error: missing terminating " character
    make[2]: *** [drivers/hid/hid-input.o] Error 1
    make[1]: *** [drivers/hid] Error 2
    make: *** [drivers] Error 2
    make: *** Waiting for unfinished jobs....
    Any ideas?
    Thank you
  1. The Android Head Unit Build - The Quest for Power
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 08-26-2013, 06:20 PM
  2. The Android Head Unit Build - Hardware Overview
    Last Post: 07-26-2013, 02:43 PM
  3. The Android Head Unit Build - Touchscreen Setup
    Last Post: 07-11-2013, 01:47 PM
  4. Replies: 25
    Last Post: 07-09-2013, 02:22 PM
  5. Android as a head unit
    By S_K_U_N_X in forum General Hardware Discussion
    Last Post: 06-17-2013, 12:28 AM
