Results 21 to 30 of 32
Thread: Automotive Computing (R)Evolution - The Android Head Unit Build - Road Test!
  1. #21
    Feb 2005
    West Valley City, Utah
    Quote Originally Posted by JamesE View Post
    I'm surprised to hear that the heat affected the life of the battery back so dramatically. I believe Lithium Ion batteries, such as those used by your battery pack, can be affected by heat in this way. I suppose it is good that you are conducting the trial during the summer so you realized the problem quickly.
    The lead-acid type of your Kinetik HC600 battery surely is not affected by heat as a lithium ion battery would be. I like the idea of the ODRIOD being "always on". I wonder if the draw is low enough that it could simply be powered by the vehicle's factory battery even when the car is off? If not a second small lead-acid style battery wouldn't be too bad.
    why not lipo batteries instead of such a small lithium ion type?
    http://m.aliexpress.com/item/6248242...bilesitedetail
    this is just a cheap single cell lipo battery like you would have in radio control with a dc regulator attached in a fancy case. I jump started my car off of a small 4000 mah 3 cell lipo battery. it weighs less then a pound and is capable of 1200watts continuous power and 1600watts peak power@12vs. it costs about $25.
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
  2. #22
    Aug 2012
    Any news of the image zip?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by mikecwel View Post
    Call me the android newb but how do i image the kernel files without zipping everything? Aside from a Nandroid backup i've never done this before.
    Live mp3Car Facebook Chat
  4. #24
    Aug 2012
    Hi,
    I finally managed to get the touchscreen to work
    Thank for your guide but I found some errors.
    I now have the same problem as you.
    My touchscreen is not responding all around the screen, the touch area seams to be a little bit smaller than the screen. I must now find a way to calibrate that.
    I'm no programmer and a newb in android and linux so must look around the web to find some help ;-)
    To get the screen a little bit bigger, i played with the build.prop and set the dpi to 192.
    Doing that I lost the bottom softkeys but another line in build.prop brought them back. Not all...only home, back and recent apps. I lost the volume controls :-(
    I will be using my car stereo with this carpc setup so I will have volume control...
    To play music I use MortPlayer found in PlayStore. It is fine because it can play music from an external HDD and I like its look.
    Thank you for your post.
    In a month I will post my setup
  5. #25
    Feb 2012
    Quote Originally Posted by Sonicxtacy02 View Post
    Working on it. The touchscreen fix didn't work for me, but i'm working with the people to try to get it solved before building the image. Hope to have it tonight.
    FYI the "help" thread is here
    Re: the touchscreen calibration
    Is there any update on the status of this? I'm working on something similar to you but with a Minix Neo X5. My lilliput was recognized out of the box but of course has the switched axis issue. Just starting to learn how to re-compile a kernel with changing the usbhid input as you did but not quite there yet. I assume that once I get the axis flipped I will still have the issue that others here do with not being able to hit the edges of the screen. Right now I can hit the top edge but not the other 3.
    Re: GPS
    I believe you said you have a BU-353-S4. I also have a BU-353-S4 and the PL2303 software does not seem to recognize it. Which options did you use for it to see yours? I tried the app that is made by Prolific (Prolific PL2303 USB-UART) and it does recognize that data is coming in but the text is so small I can't see if it is valid data or not. I also used my phone as a USB bluetooth device and the PL2303 software does recognize it and I can use google maps with it so it does work via bluetooth.
    Thanks for any help you can provide. It would be awesome to get this project up and running
  6. #26
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by gumby_ View Post
    Re: GPS
    Still no fix on the touchscreen issue. The problem I'm experiencing might not happen to you though. The problem with the ODROID is its using the default HIDINPUT driver and not the driver which allows us to set raw coordinates. I'm going to use this weekend to tinker around some more in hopes of hacking menuconfig into using the correct driver.
    I did not have to change any settings other than starting the PL-2303 app to start at boot. The coordinates do show up very small, but if you see coordinates at all it should be valid data. I see no coordinates at all if the GPS isn't plugged in. It sounds like you may have the wrong app. This is the one you want. Follow the instructions to set the apps service to be the location provider and it should just work.
  7. #27
    Feb 2012
    I have that app, it is the one that for me is not returning any data unless I try using it with my phone's GPS via bluetooth. Using the BU-353-S4 I get nothing. Looking at the data received when using the other app, I think the issue may be with the data I am actually receiving or rather what the driver is doing with it. It does not look like GPS data at all. I am guessing it is an issue with the OS and not so much software or the GPS hardware
  8. #28
    Feb 2012
    Hi Sonicxtacy02,
    Great writeup. Looking forward to seeing more progress on this install. I'm in the process of getting my Minix Neo X5 android install completed. Having the same issues with my lilliput as you did however did manage to apply a patch that at least gets it working although the top and bottom edges of the screen are still flaky like yours. Which mic did you use for the android build? I am looking to get one but not sure what to get. Also, how are you running the audio out from the Odroid? My Neo X5 has hdmi, spdif, and analog outputs. My stereo only takes the analog input (3.5mm jack) but I may look into something else as a headunit in the future.
    Keep the updates coming
  9. #29
    May 2012
    Grandville, MI
    If you happen to need to do work on development I just saw a suggestion that works pretty well...
    If you have hyper-v or vmware or a similar virtual computer interface on your computer and you have a standard PC you can run Android x86 on it. I just installed android 4.3 on a virtual machine and that thing is pretty cool. They have different versions of android you can use. It is much faster than the android emulator that you can run.
    Would be cool if you could change the screen dimensions with it but I didn't see an option for that for reasonable resolutions.
    Rodney
  10. #30
    Jun 2009
    Charlottesville, Virginia, United States
    Any updates on this build. I have google Glass and want to build something like this, so that I can interact with it through glass and voice actions.
  1. The Android Head Unit Build - The Quest for Power
    By Sonicxtacy02 in forum Mp3Car Blog Talk
    Last Post: 08-26-2013, 06:20 PM
  2. The Android Head Unit Build - Hardware Overview
    Last Post: 07-26-2013, 02:43 PM
  3. The Android Head Unit Build - Touchscreen Setup
    Last Post: 07-11-2013, 01:47 PM
  4. Replies: 25
    Last Post: 07-09-2013, 02:22 PM
  5. Android as a head unit
    By S_K_U_N_X in forum General Hardware Discussion
    Last Post: 06-17-2013, 12:28 AM
