Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 54
Thread: "What's going on with the forum?"
  1. #11
    Feb 2004
    Also, I noticed that the WYSIWYG icons on IE7 don't seem to work..
    Like the Insert Link button pops up
    http://www.mp3car.com/vbulletin/sugg.../ieprompt.html
    with "page not found".
    This was happening for some time it seems, before today's break..
  2. #12
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by RedGTiVR6 View Post
    This was an uninstall..not an install that went south.
    Same thing.... thats why you need pre production / production areas so you can test before making changes in your enviroment.
    'Change Managment'
    Terran
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    Thanks for the suggestions ccsnet, I knew you would be in here with them.
    However, I don't have control over that aspect of this company.
    Jan Bennett
  4. #14
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    You can use this example as a reason for a dev environment to see how changes work prior to putting the change in front of us.
    Better for business to reduce the user population from seeing this when possible.
    Not picking on you, attempting to suggest a way to improve. This type of conversation is one I deal with daily (professional software QA).
    Cheers and glad you are getting things worked on.
    TruckinMP3
    Read the FAQ!
  5. #15
    Jan 2003
    I'm not quite sure how to take that first line.... re the 2nd line ... if your supposed to be the one maintaining the forum and adding to it can I suggest you bring this up asap..... I'm pretty sure FirberOptic used to test every thing...
    Terran
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Giuliano View Post
    Uploading images via the User CP is broken..
    The database insert goes all wonky.
    I have 2-3 blank "images" in my list that I can't delete, because it says it can't find the files.
    Can someone get rid of those?
    This should all be working fine now.
    I'm still looking into deleting those images that were uploaded while this issues was present though.
    Jan Bennett
  7. #17
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by long.1 View Post
    I'm not sure if it's related, but I can't seem to do any of the "Edit" functions in the "User CP: Settings & Options". When I try to Edit Signature/Profile/Avatar/etc, I get the following message: "Undefined authentication type".
    Cheers,
    Long.1
    I'm looking into this right now.
    Jan Bennett
  8. #18
    Jun 2002
    Colorado
    I think you'll find it is related to security cookies.
    I had a similar message signing in until I cleared cookies and re-signed in.
    TruckinMP3
    Read the FAQ!
  9. #19
    _
    Mar 2004
    Little Elm, Texas
    Are you able to access the UserCP menus now? Edit signiture, etc?
    Thanks for the info, the manner in which you present things is greatly appreciated Truckin.
    I too worked in QA for a while for CRM software customizations, so I understand the need for test environments and have asked about them in the past for this site.
    Jan Bennett
  10. #20
  1. A "what's broke" thread
    By tibby01 in forum General Hardware Discussion
    Last Post: 03-12-2007, 09:06 AM
  2. Ok here's another, "What's wrong with this picture"
    By CrazyLittle in forum Off Topic
    Last Post: 04-25-2002, 11:11 AM
