Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 54
Thread: "What's going on with the forum?"
  1. #21
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Quote Originally Posted by RedGTiVR6 View Post
    Are you able to access the UserCP menus now? Edit signiture, etc?
    No, the following aren't working yet:
    Under Settings & Options:
    • Edit Signature
    • Edit Email & Password
    • Edit Profile
    • Edit CarPC Specs
    • Edit Options
    • Edit Avatar
    • Edit Profile Picture
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
  2. #22
    _
    Mar 2004
    Little Elm, Texas
    Did you clear your cookies DJiK, like Truckin mentioned?
    My post was in response to Truckin's post.
    I cleared my cookies and was not able to get into those areas. I have not made any changes to the forum, files, or code to work on this as I'm trying to research what could be causing it first.
    Jan Bennett
  3. #23
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Enforcer View Post
    I get an error message when I try to edit a post.
    What error?
    I just clicked to edit my post and it worked fine.
    Jan Bennett
  4. #24
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Thanks for the info, the manner in which you present things is greatly appreciated Truckin.
    I too worked in QA for a while for CRM software customizations, so I understand the need for test environments and have asked about them in the past for this site.
    Edit of signature results in: Undefined authentication type
    Which is what I was getting earlier attempting to connect to the Forums. Clearing cookies fixed being able to connect, but not edit signature.
    bummer.
    TruckinMP3
    Read the FAQ!
  5. #25
    _
    Mar 2004
    Little Elm, Texas
    Thanks.
    I'm still looking into it!
    Jan Bennett
  6. #26
    Nov 2004
    St Louis
    Quote Originally Posted by TruckinMP3 View Post
    bummer.
  7. #27
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    What error?
    Well the first time I click 'edit' I get
    Code:
    Line: 171
    Error: 'null' is null or not an object
    And if I press it again I get
    Code:
    Line: 276
    Error: 'vB_Editor[...].wysiwyg_mode' is null or not an object
    And when I clear the message it will then open up and allow me to edit.
  8. #28
    Jun 2002
    Colorado
    Odd results for me.
    At work with FireFox 2 I can login, read, and post.
    At home also with FireFox 2 I am not able to login (see prior message)
    I thought all the local settings where the same but I guess I missed one.
    I hope the searching for why is productive.
    TruckinMP3
    Read the FAQ!
  9. #29
    Apr 2005
    Queens, New York
    Where is the new classified's section? It is not on my top menu bar anymore...(next to User CP, FAQ, Member menu)
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  10. #30
    Constant Bitrate long.1's Avatar
    Jul 2006
    Melbourne, Australia
    Quote Originally Posted by Cheekz185 View Post
    The new classifieds section was moved at the end of March as advised in New Classified Section.
    Cheers,
    Long.1
  1. A "what's broke" thread
    By tibby01 in forum General Hardware Discussion
    Last Post: 03-12-2007, 09:06 AM
  2. Ok here's another, "What's wrong with this picture"
    By CrazyLittle in forum Off Topic
    Last Post: 04-25-2002, 11:11 AM
