Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: This picture weights 1.94Kb, should be weighs.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    As above.
    When a image is too big we get a little heading which tells us the dimensions plus how big it is, but it says weights rather than the correct weighs.
    A small thing I know, but hey, might as well get it correct
    _
    Mar 2004
    Little Elm, Texas
    lol
    many times, these modifications are written by folks who speak something other than english as a first language.
    I'll go check it real quick.
    speaking of which, what do you think would be a good size for the pictures? or do you not run into that issue all that often?
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    where are you seeing it exactly?
    Jan Bennett
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well it all really depends on what PC I am viewing it from.
    If it is my home PC or work PC, then 'weight' doesn't really matter and the dimensions can be anything up to 1024 x 768 before I have an issue, some others will be able to handle even bigger. However 800x600 is probably OK
    However if I am using my old laptop or a car PC then even 800x600 is too big, so 640x480 or even smaller would be better.
    *edit, OK you've fixed it
    _
    Mar 2004
    Little Elm, Texas
    but where?
    Like in the yellow header of the picture I just posted?
    Can you check it again where you saw it before? I think I found the vBulletin phrase where it was at and corrected it, just want to be sure.
    Jan Bennett
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Sorry, yes it was the yellow bar.
    And I did check back, it's near the end of My Thread 10, there is a large Smiley picture, it was on that.
    _
    Mar 2004
    Little Elm, Texas
    is it still there or no?
    Jan Bennett
    Elsewhere
    No, I'm seeing the same thing... Damn heavy photos!
    Wait... It's actually supposed to say that the picture weighs X amount?
    What odd terminology...
    How about the Wiki?
  1. Replies: 10
    Last Post: 11-21-2005, 08:01 PM
  2. Replies: 78
    Last Post: 09-08-2005, 07:29 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  4. 200 Watt DC-DC PSU
    By Deadnick in forum Power Supplies
    Last Post: 05-22-2004, 04:08 PM
  5. LCD picture quality not good. Will shielding help?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 10:51 AM
