Can we have a code tag button on the quick reply box and also change the button from # to something that indicates code better, lsimilar to the php one but with code written rather than php.
cheers.
Printable View
cheers.
I'll look at adding the button to the quick reply, but I'm not sure about changing the image.
I say this because this is the standard across all vBulletin boards.
code and php icons have been added to quick edit and quick reply boxes.
I'm not sure but I think the problem that Red is pointing out is that if the image is changed then whenever an update is done to the forum then the image would have to be changed again. But I could be wrong...
Well, that too. I'd have to remember to copy it over along with everything else.
If someone wants to take the time to make a new image that looks IDENTICAL only says code instead of PHP I'll see about adding it. It just cannot look like a 4th grader did it...I know that's how it would look if I did it.
