Results 1 to 6 of 6
Thread: code tags.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    code tags.
    Can we have a code tag button on the quick reply box and also change the button from # to something that indicates code better, lsimilar to the php one but with code written rather than php.
    cheers.
    _
    Mar 2004
    Little Elm, Texas
    I'll look at adding the button to the quick reply, but I'm not sure about changing the image.
    I say this because this is the standard across all vBulletin boards.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    code and php icons have been added to quick edit and quick reply boxes.
    Jan Bennett
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by RedGTiVR6 View Post
    Thanks for adding
    However now for my mandatory moan
    Well it may be standard, but it doesn't shout out to me it's a code tag. Which is why I always type the damn thing when I can be bothered/remember.
    Super Moderator xBrady's Avatar
    USA
    I'm not sure but I think the problem that Red is pointing out is that if the image is changed then whenever an update is done to the forum then the image would have to be changed again. But I could be wrong...
    Installed.
    -GPSSecure- - GPS Tracking
    _
    Mar 2004
    Little Elm, Texas
    Well, that too. I'd have to remember to copy it over along with everything else.
    If someone wants to take the time to make a new image that looks IDENTICAL only says code instead of PHP I'll see about adding it. It just cannot look like a 4th grader did it...I know that's how it would look if I did it.
    Jan Bennett
  1. GPS/MapPoint VB Source Code
    By stevieg in forum Software & Software Development
    Last Post: 01-28-2011, 03:59 PM
  2. Weird Registration Code and Hardware Code problem
    By lookinco in forum StreetDeck
    Last Post: 09-30-2006, 02:25 AM
  3. I need help with a pretty major function....can someone help me code it? / find one?
    By wardemon666 in forum Software & Software Development
    Last Post: 07-03-2006, 08:20 PM
  4. Replies: 0
    Last Post: 06-11-2006, 05:49 PM
  5. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 03:43 PM
