Results 1 to 2 of 2
Thread: Code Tags Not working correctly
    Mar 2006
    Colorado, but Canadian!
    The [CODE ] [ /CODE ] tags are cropping the text if it is too long. There is a scrollbar on the bottom. Since the "yellow-ish" part extends the correct table width, I am not sure why there is a frame inside of it with a fixed width. Looks pretty bad IMHO.
    1.9in x 2.9in -- 47mm x 73mm
    _
    Mar 2004
    Little Elm, Texas
    looking into it.
    thanks for brining it up.
    Jan Bennett
  1. Audio not working correctly in SD
    By nicehomeslice in forum Infill T3
    Last Post: 02-08-2008, 12:52 AM
  2. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  3. BR-3 VB6 Sample Source Code
    By Zharvek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-15-2007, 08:43 AM
  4. Head Unit 'code' - help!
    By Laidback in forum Car Audio
    Last Post: 06-10-2005, 09:53 AM
  5. Everything working correctly?
    By bgoodman in forum Off Topic
    Last Post: 09-15-2002, 01:13 AM
