Results 1 to 10 of 15
Thread: put linx and other info in signature, but a 255 character limit???
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    edmond, oklahoma
    help! i cant put a link to my project in my signature. you can see a display of my typed progress. but i cant seem to figure out how to add more in my signature. i see many others with way more info than i have in mine. i want to add more! help is greatly appreciated.
    Gathering parts----99% (I'll always want something else, its never 100%)
    Learning Centrafuse
    First Actual 98 Blazer LT Install
    First 08 Aveo5 SV Install
    87 Fiero GT waiting
    Elsewhere
    Moved to SUggestions/Comments.
    Please try to post int he appropriate forum.
    How about the Wiki?
    Apr 2007
    edmond, oklahoma
    oh oops, my bad. thank you.
    Learning Centrafuse
    87 Fiero GT waiting
    _
    Mar 2004
    Little Elm, Texas
    sorry - but 255 characters is the normal across most forums on the internet.
    You say others have more info than you, I'd like to know who specifically because I don't think they do.
    You should get creative with the way you put things in your signature.
    We have a limit for a reason.
    Jan Bennett
    Mar 2006
    Colorado, but Canadian!
    I must say, I dont like the limit on the total length with code markup. I understand visible limitations, but when links get long, the signature automatically poops out. A good example is since you updated the forum to use string based lookups for the address instead of numbers.
    So instead of "/vbulletin/forum/123.html" it is now "/vbulletin/forum/very-long-title-to-some-thread-that-takes-up-lots-of-space.html". So if you want a link to a post here, you just ate up almost all your character allowances. That sort of thing. I think it is at 500? I know that it has yelled at me plenty of times, and I do agree with a limit for visible text (255 is good), but how about upping the text+VB code?
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2007
    edmond, oklahoma
    i cant fit my progress in and a link to my project buildup that i should have put in the worklog.
    Learning Centrafuse
    87 Fiero GT waiting
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by 2k1Toaster View Post
    (although there are ways of finding the shorter link and using that )
    I have had to get creative and drop a lot of bits out of mine.
    One trick I have noticed is:
    Don't put the http:\\ in a link, just start it with www
    The http:\\ will be put in when you save it but it doesn't come out of the 255 (unless you edit it again, then you have to remove it again)
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Quote Originally Posted by Enforcer View Post
    What a pain....
    Rafster
    _
    Mar 2004
    Little Elm, Texas
    Your signautre is just that...a signature. A bit about yourself and your project. It's not a life story. It's not a place to post and explain in detail where you stand on your project or to tell the world that you'll never be happy with it. It's your signature. If you want to tell the world that you still need to do this, that, and the other thing, save it for your work log...and link to it.
    However, I have increased the limit with BBCode in signatures.
    Jan Bennett
    Apr 2007
    edmond, oklahoma
    how can i post a link to my worklog? i cant fit the link and my % done. am i just sh outta luck?
    Learning Centrafuse
    87 Fiero GT waiting
