that would require getting into the database and changing the fields on every single post you've made or will make manually. I can tell you right now it's not going to happen.
Messing with the database like that is generally not a good idea.
Anyone know how to make it less obvious that I'm posting from work? Ideally, I'd hide / change the timestamp on a post... ideas?
Jan Bennett
1.9in x 2.9in -- 47mm x 73mm
