Results 1 to 3 of 3
Thread: cant change password or e-mail
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    when i go to edit password i get an error saying that the entered password does not match what is on record.... the only 2 boxes there are for new password
    same goes if i only want to change my email
    The password you have entered does not match your current one. Please press the back button, enter the correct details and try again. Don't forget that the password is case sensitive. Forgotten your password? Click here!
    funny thing i can login fine...
    Blessed are the "cracked" for it is they who let in the light.
    Mar 2007
    I've had the same issue for over a month - I just use the reset password now to login. Someday I'm sure they'll fix it and then I can set it to a password I can actually remember.
    Edit:
    After seeing in a thread from February that old accounts have this issue with the updated forum, hiding the current password field, I used the FireBug plugin in FireFox to make the current password field visible again.
    I changed:
    <input id="currentpassword" type="hidden" name="currentpassword">
    to:
    <input id="currentpassword" type="textbox" name="currentpassword">
    This will add a textbox directly under "Edit Email & Password" where you can enter your old password. This won't say "current password" or anything, but it is the quickest and simplest way to get the old password field visible so it can be used for a password change.
    Nov 2010
    I also have this same issue. Is it possible to fix it on the forum side?
  1. Help with Password
    By KennyKen in forum Software & Software Development
    Last Post: 07-13-2006, 07:19 PM
  2. change user/password
    By gameboy in forum EZSync
    Last Post: 06-10-2005, 06:26 PM
  3. password in to start car
    By Seraph in forum General Hardware Discussion
    Last Post: 10-09-2004, 01:10 PM
  4. Replies: 1
    Last Post: 05-21-2003, 05:36 PM
  5. ebay change of password
    By cruzc_99 in forum Off Topic
    Last Post: 01-22-2002, 03:43 PM
