Results 1 to 10 of 15
Thread: Search SUCKS!!
    Dec 2007
    NY
    Search SUCKS!!
    The search function in this forum is abysmal at best. This is the only forum I've been to where if you put in multiple specific words to search for, the result will be MULTIPLE threads with only one of the words within the thread. This makes absolutely no sense; if I was at all interested in a thread, allow me the courtesy to input that one word for the result of that particular thread. Don't give me that thread because it contained ONE of the three words I'm searching for. My time is consistently wasted with searching through thread results in this forum that don't contain EXACTLY what I am searching for. And then when people get fed up of searching through irrelevant threads returned by the search, the response is, "Use search". NO DAMN IT, it's useless! Personally, I would prefer to use search instead of posting the same thing for the millionth time....but not with the search capabilities of this forum.
    Raw Wave
    Nov 2009
    Last time I used google very successfully (first returns).
    Wanting to find my UIBI posts, I simply used mp3car uibi oldspark
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    As pointed out by OldSpark, its best to use google itself.... Even tho takes a little more time, Does end up being much quicker.
    Enter The Following Line Into Google....
    site:mp3car.com Stereo Replacement Ideas
    the above line will search only mp3car.com with the keywords in bold,
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Have you tried using "AND" between the terms? I know that vB doesn't look to see if all terms are in a single post/title, but it's supposed to work if you use "AND".
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Dec 2007
    NY
    I've tried AND, quotes, plus sign, none work. It's just sad. I wish/hope more people will complain so this can be fixed/changed...unless it simply doesn't annoy anyone else. I think the fact that people resort to using google speaks for itself. I don't use google because a lot of times I like to search titles only...unless that's possible with google, let me know. Besides, using google is flawed in searching multiple words, but is waaaaay better than this sites search function. Come on, let's get this fixed.
    Jan 2008
    which other forums are you on, and what software do they use?
    i'm also on hidplanet(new vbulletin 4.1) and club3g(old vbulletin 3.8) and both have done the same thing as long as i can remember. i have simply started searching via the
    google 'site:' method any time i need it...
    Nov 2010
    Panama City Beach
    There is a hack that can be incorporated, but it's something the forum admin has to do.
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    a hack to use the old vb3 search? Or a hack to search the site via google? I can look for both
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    The way I believe search works, is that it tries to use all of your words first, then it uses them individually. If I search for power supply, the first 8 results all have "power supply", the rest have either power or supply
  1. My IP sucks
    By 84RegalRider in forum Off Topic
    Last Post: 09-08-2008, 08:12 AM
  2. IE7 Sucks
    By muldrick in forum Off Topic
    Last Post: 11-15-2006, 02:19 PM
  3. The UN sucks the big one
    By JaymzRR in forum Off Topic
    Last Post: 09-04-2005, 03:28 AM
  4. Replies: 0
    Last Post: 07-29-2005, 12:46 PM
