I'm not sure why you're getting those... but we are running a beta version of the forum software now so i would bet that it's somehow related
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 62 bytes) in /home/virtual/site34/fst/var/www/html/vbulletin/global.php on line 146
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 0 bytes) in Unknown on line 0
I keep getting this!
makes me![]()
please make bosstone![]()
and I just wanted to say thanks for all the hard work you guys do with this forum!!!!!!!!
BossTone74
and I hate it, my ****'s all moved around![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
And the skin went to the default skin, and then back to the old forum skin.
And the notification mails have stopped being sent. I started a thread about it, but only 3 people seem to have the problem.
4x4 in a turbo stylee.
Originally Posted by bosstone74
I got this too for a while. It's gone now, I changed nothing my end, even using the same session of IE6:
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 89 bytes) in /home/virtual/site34/fst/var/www/html/vbulletin/global.php on line 146
This is a new thing for me. I ran windows update yesterday which did grab some patches to IE6 (quite a few actually), but things were running ok earlier today after the update. My system config is (if it's useful at all to help track the problem down):
P3-800, 512Mb Ram, ASUS CUSL2
Win98SE 4.10.2222 A
IE 6.0.2800.1106IC
IE Cipher Strength : 128-bit
IE Update Versions: SP1; Q324929; q313829; Q810847; Q818529; Q813951; Q330994;
Rob
ahhh me too ''Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 737280 bytes) in /home/virtual/site34/fst/var/www/html/vbulletin/showthread.php(1578) : eval()'d code on line 298''
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 15 bytes) in Unknown on line 0
it's a known error with no real fix
Just got that one. From my knowledge, its because of a few things.. You have bad RAM (really, it could be that simple) or your PHP buffer size is changingFatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 737280 bytes) in /home/virtual/site34/fst/var/www/html/vbulletin/showthread.php(1578) : eval()'d code on line 298
Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 15 bytes) in Unknown on line 0You can set the buffer in a .htaccess file.
1993 BMW 325is - 15.2sec
Care to elaborate?Originally Posted by SiGmA_X
Sounds like the server box can't alllocate the memeory required to run the page. Either the vB is leaking memory like a seive, or vB v3beta has a lot higher memory requirements.
